#1 |
3.4 V-6 Timing Belt Replacement ?
I recently purchased my 2001 Tacoma TRD with 104K so I have a couple of questions concerning the timing belt replacement, tools required etc. I have previously replaced the T-belt on a 95 Pathfinder and one of my concerns when performing that job was breaking loose the Harmonic Balancer bolt. I put the gear shifter in 1st gear and broke the bolt loose with a long breaker bar. No harm no foul but perhaps I was just lucky nothing snapped in the drive train.
The Tacoma Factory Manual illustrates a special tool to secure the harmonic balancer while loosening the harmonic balancer bolt. My question is do I absolutely need the special tool to perform the job or is there another safe method of breaking loose the harmonic balancer bolt without damaging anything else? Or put another way the preferred method? Second, while I am in there should I replace the water pump with another Toyota OEM water pump? I have no history with Tacoma's but as I when I replaced the 95 Pathfinder T-Belt @ 84K the water pump started making noise @ 129K and I had to go back in to replace that component and go through the entire process again. Anything else I need to be aware of . . . TIA
__________________
srsupertrap |
#2 |
You may as well replace the water pump while you've got the front of the engine disassembled.
If you live near a well-equipped tool rental outlet you may be able to rent the special service tool (SST). Some folks have fabricated tools / pieces required. Trying to break and re-tighten certain bolts without some sort of special tool is a major PITA. |
#3 |
On my 95 V-6, I had the belt replaced at 100K. Did not do water pump.
I'll go in a different direction here. I do my own brakes, fuel filter, belts, master cylinders, etc...and am relativley mechanically inclined, but have never done a timing belt. Most Toyota dealerships have monthly timing belt specials for around $200- $225. I don't have alot of specialty tools, & dont want to spend a full day doing a project like that with the headaches. |
#4 |
Pre Senior Citizen
Definately replace the water pump & thermostat while you're in there.
Also, replace the accessory belts too. Peace of mind. My husband and I replaced the water pump on my 96 (3.4L) several years back. We didn't change the timing belt because we had the Saturn dealership (where I bought the truck) pay for having it changed when we purchased the truck (they refused to pay to have the other stuff done). I owned the truck for about 10K miles before I started loosing radiator fluid in the overflow tank. I kept topping it off for about a year (can't remember exactly) before the leak was noticable enough that I knew where it was coming from. The water pump never failed, but the gasket material that seals it to the side of the block deteriorated and that's where the leak came from. Here's a writeup on how we did it: http://www.lieblweb.com/tacoma/Mecha.../WaterPump.htm
__________________
Our Homepage http://www.lieblweb.com/ My truck photo gallery http://www.lieblweb.com/cpg/thumbnails.php?album=16 |
#5 | |
__________________
That Which Does Not Kill You Only Makes you Stronger.......This Is Why I Walk the Thin Blue Line. 2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer, 1" body lift. |
#6 |
Chemical Disaster Master
Haynes says to jam the flexplate or flywheel by sticking something in and catching a bolt on it. Sounds nearly impossible to me.
__________________
2009. Ok, now what? |
#7 |
[quote=Janster;247947]
Here's a writeup on how we did it: http://www.lieblweb.com/tacoma/Mechanical/WaterPump/WaterPump.htm[/quote] Janster, That's a nice write up you did, I am inclined to agree with you and replace everything once I get in there. When I replaced my Pathfinder water pump I let it sit overnight to cure before filling the radiator and going to work. Makes me wonder how dealerships & independent shops handle those repairs since time is money. Do they dare filling the radiator before the RTV has cured and risk a potential leak
__________________
srsupertrap |
| Display Modes | |
| timing belt/chain | mudjunkie | 1st Gen. Tacomas | 10 | 08-31-2008 08:39 PM |
| Timing belt or chain? | BajaTrd | 2nd Gen. Tacomas | 6 | 04-06-2008 09:31 PM |
| timing belt | 03eiger | Technical Chat | 12 | 03-29-2008 07:29 PM |
| How many miles on your timing belt?? | CutnShootTaco | Technical Chat | 5 | 09-07-2007 09:04 AM |
| timing belt question | kiwi | 1st Gen. Tacomas | 17 | 11-16-2006 07:51 AM |
