School me on Leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fiddynut, Dec 22, 2011.
  1. Dec 22, 2011 at 10:25 PM
    #21
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    I have a set of stock leafs off my 04. They were only used for two years until I lifted it.
  2. Dec 22, 2011 at 11:06 PM
    #22
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    OP:
    If you dont like they way the billy/toytec springs ride up front get rid of the toytec springs, get some stock coils (newer ones like from an 01-04 so you know they wont be saggy), and a wheelers 4 pack and billy 5125 for the back.
    You will be stock height and will ride better than stock.
    Getting a used set of leafs from another memeber is an option. Keep in mind that 95-97 leafs are different than 98-04. But I wouldn't buy used leafs unless you know for a fact they have hardly any use, because like others have said, these leaf packs are known for wearing our super quick.
  3. Dec 23, 2011 at 2:39 PM
    #23
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    true, depending on how you use your truck. towing, 4 wheeling etc
  4. Dec 23, 2011 at 4:50 PM
    #24
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Okay so you have Eibachs basically??
    Best riding lift and non lift set up is OME. If i was you and NOT getting a lift, get some OME 880 coils and Nitrocharger shocks up front, and the Wheelers 4 pack with nitrochargers
    A slight lift and good ride would be OME 881 coils on nitrocharger shocksand wheelers 5 pack leafs with nitrochargers.
    Eibachs("toyotech coils") are very stiff and give 3'' of lift.
    the OME coils give 1'' and 2-2.5'' respectively but ride much smoother. I think you will be happy with those coils much more.
    5100 shocks also tend to stiffen up over time. Nitro chargers are smoother all around.
    You could eaisly sell the 5100s and Eibachs.
  5. Dec 23, 2011 at 11:56 PM
    #25
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Your choices are stiff strong and responsive or saggy weak and wollowy. I guess if you don't like one you can go back to the other?
    Wait... did you ever get UCAs for the front lift? maybe bump steer is your problem?
  6. Dec 24, 2011 at 8:50 AM
    #26
    Fiddynut
    Fiddynut [OP] Well-Known Member
    San Diego
    03 TRD Double cab
    Bilstein 5100s on 32" BFGs
    No the coils rebound like crazy and fully extend the shocks.
  7. Dec 27, 2011 at 10:14 PM
    #27
    Fiddynut
    San Diego
    03 TRD Double cab
    I was told that when they installed the 3 leaf pack that they took out the over load spring.
    While looking at a few threads on leafs I noticed that the only difference between mine and the stock ones I saw was the 3 new leafs. Am I wrong?
  8. Dec 27, 2011 at 10:22 PM
    #28
    TacoMX
    Jonathan
    Deltona, Florida
    Your stock overload spring is still in. That is supposed to come out with the 3-leaf AAL (Is that the ICON AAL?)
  9. Dec 27, 2011 at 10:37 PM
    #29
    Fiddynut
    San Diego
    03 TRD Double cab
    No it's the deaver. I think they are all the same. Rad all I need are some stock ubolts.
    Thanks man!
  10. Dec 27, 2011 at 10:37 PM
    #30
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    not sure if i'm following this correctly but with that overload still there you must have roughly 4" of lift, depending on your bilsteins they might be maxed out hard to tell from pic
  11. Dec 27, 2011 at 10:41 PM
    #31
    TacoMX
    Jonathan
    Deltona, Florida
    Not quite, with the overload in he is probably getting about 2.5'' max.
    The 3 leaf AAL gives 1.5'', and the overload leaf is like 3/4'' thick; so the 5100's should be fine.
  12. Dec 27, 2011 at 10:45 PM
    #32
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Its a 3 leaf AAL ? how much lift is it supposed to give ??
  13. Dec 27, 2011 at 10:46 PM
    #33
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    OOPS sorry didnt read that 3 leafs for 1.5" ?
  14. Dec 27, 2011 at 10:46 PM
    #34
    Fiddynut
    San Diego
    03 TRD Double cab
    1.5 inches.
  15. Dec 27, 2011 at 10:48 PM
    #35
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Damn thats like laying 3 pieces of flat steel on top of one another, i added 2 leafs per side to mine & got 3", had to dump the overload, too high with it
  16. Dec 27, 2011 at 10:50 PM
    #36
    TacoMX
    Jonathan
    Deltona, Florida
  17. Dec 27, 2011 at 10:54 PM
    #37
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Not a good pic but this was taken right after spring rebuild w/overload
    tires then were BFG A/T's KO's 32" 's
  18. Dec 27, 2011 at 10:55 PM
    #38
    TacoMX
    Jonathan
    Deltona, Florida
    Spring rebuild :confused:
  19. Dec 27, 2011 at 11:20 PM
    #39
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    yup, spring rebuild or spring refresh whatever yer pleasure....:cool:
    stock 1st gen. leafs with the addition of 2 Ford springs per side
    3" lift gained , have since dumped overload
  20. Dec 28, 2011 at 12:26 AM
    #40
    TacoMX
    Jonathan
    Deltona, Florida
    oooooh...I remember seeing that.
    Thats a pretty cool setup.
    How does it ride?
