2 electrode spark plug gauge
Old 01-12-2012, 08:53 PM   #1
kortiz [OP] kortiz is offline
kortiz is on a distinguished road
kortiz's Tacoma Gallery
I bought the replacement spark plugs for my 2001 tacoma pre runner. These spark plugs have 2 electrodes and I was wondering how to calibrate them. I read that the gauge has to measure .043 but I want to know how to measure it. Is it vertically in this case since I have 2 electrodes?
When you have one electrode you measure the gauge horizontally because the electrode sits on top, but in this case the electrodes are kind of in the side so I am wondering/
Old 01-12-2012, 08:58 PM   #2
Don't give up here just yet
2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed2TRunner is one of the sharper tools in the shed
2TRunner's Avatar
2TRunner's Tacoma Gallery
Put them in the way they are.
Don't really need to worry about plug gap to much with a double (or more) electrode spark plug.
Old 01-13-2012, 06:10 AM   #3
twfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shed
Army: Engineer's
twfsa's Tacoma Gallery
Hey check the gap its not always correct ^^^^ thats bullshit!
Old 01-13-2012, 06:15 AM   #4
facemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shedfacemob is one of the sharper tools in the shed
facemob's Avatar
facemob's Tacoma Gallery
i think if you use the same general concept as a single ground electrode you will be fine. thats how i did it. actually, yes, measure the same way, it will be fine. but definitely measure because it wont always be correct from the box
Old 01-13-2012, 07:13 AM   #5
Taco John is a name known to allTaco John is a name known to allTaco John is a name known to allTaco John is a name known to allTaco John is a name known to allTaco John is a name known to all
Taco John's Tacoma Gallery
I run Bosch Platinum +2 in my wifes car (3rd set) and my understanding is they are set right (or at least close to it) from the factory and should not be gapped. I'm not really sure how you would do it anyway. the "electrode" is fully covered with ceramic and the grounds don't have anything square to reference off off.
The spark travels differently on that style of plug. It follows down the insulator more before jumping the gap.
Old 01-13-2012, 07:19 AM   #6
4WD 4WD is offline
cRaZy oLdmAn
4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed
4WD's Avatar
4WD's Tacoma Gallery
This, they are set at the manufacturer & the spark is thrown across the electrode (horizontally) as opposed to standard single electrode plugs (vertical)
Old 01-13-2012, 07:22 AM   #7
4WD 4WD is offline
cRaZy oLdmAn
4WD's Avatar
& I'm pretty sure this type of plug was chosen because of the 3.4-4.0
hemispherical "Hemi" combustion chamber heads
Old 01-13-2012, 07:22 AM   #8
chris4x4's Avatar
chris4x4's Tacoma Gallery
Always check the gaps.
Old 01-13-2012, 07:24 AM   #9
chris4x4's Avatar
The 1GR uses single electrode plugs, as do many other "hemi" engines. IIRC, the 3.4 uses a "wasted spark" ignition, and the double ground plugs are better in those motors.
Old 01-13-2012, 07:29 AM   #10
4WD 4WD is offline
cRaZy oLdmAn
4WD's Avatar
Engine specific I guess, just like some have had problems when replacing the Denso with Bosch, I'm running Bosch now with no issues, but then again, i'm not running anything 'cause my trans shit itself, hmmmm, may re think the whole Bosch thing if its smoking transmissions
Old 01-13-2012, 08:35 PM   #12
chris4x4's Avatar
Originally Posted by Norton View Post
Bosch did NOT run well in my wife's Toyota several years ago. That, along with the fact that Chris said to run OEM plugs, led me to just go with Denso.
(Like many here, I always do what Chris says... )
LOL!! Im not always right, Ive just found the OEM Denso plugs to run the best.
Old 01-14-2012, 05:03 AM   #14
chris4x4's Avatar
Sacrilege!
its happened
Spark plug help brandonlamb25 2nd Gen. Tacomas 5 11-28-2010 08:16 PM
single electrode spark plugs? ScootsOFP Performance and Tuning 1 10-20-2010 06:14 PM
Spark plug changes javataco 2nd Gen. Tacomas 2 07-26-2010 07:31 PM
Spark plug ? LEEP 2nd Gen. Tacomas 1 08-10-2009 05:47 AM
spark plug electrode brock 1st Gen. Tacomas 6 12-08-2008 05:20 PM
