Trans Dapt Oil Filter Relocation Install
Old 01-21-2012, 09:16 AM   #1
wesb1023 [OP] wesb1023 is offline
wesb1023 is a splendid one to beholdwesb1023 is a splendid one to beholdwesb1023 is a splendid one to beholdwesb1023 is a splendid one to beholdwesb1023 is a splendid one to beholdwesb1023 is a splendid one to beholdwesb1023 is a splendid one to behold
wesb1023's Avatar
wesb1023's Tacoma Gallery
Thought I would share my oil filter relocation install since I couldnt find any pics when I was searching for info. So here goes.....
Here is the kit, pretty easy to install.
I first used teflon tape and installed both hoses on the engine side adapter and screwed it on to the original oil filter nipple. I then had to find a place to put the filter assembly, as these hoses in this kit are already made up to be 30" long. The hoses are too long to put the filter where I mounted it, it will work for now but I am gonna shorten the hoses later.
This is where I chose to mount the filter, there is already a threaded hole in the chassis at this location. The filter adapter has three mounting holes in it, but I am sure if you wanted the one 8mmx1.25 bolt would hold the filter just fine. I just popped two more holes in the chassis and threaded them and used all three bolt holes in the adapter. This end of the hoses have a swivel built in so you can install the hoses using teflon tape and then mount the adapter.
This is the finished product, I will still have to remove the skid plate to do the oil change but that doesnt bother me, I just hated the oil running down all over everyhing when I changed my oil.
Old 01-21-2012, 09:20 AM   #2
Jdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shedJdaniel1274 is one of the sharper tools in the shed
Jdaniel1274's Tacoma Gallery
Great write up! The previous owner relocated the oil filter to inside the left fender well, make for easy access, but not ideal for off road.
Old 01-21-2012, 09:51 AM   #3
wesb1023's Avatar
Thats why I chose this location. I thought it would be more protected from flying rocks n stuff.
Old 01-21-2012, 11:53 AM   #4
bivey will become famous soon enoughbivey will become famous soon enough
bivey's Avatar
bivey's Tacoma Gallery
Keep us informed after a couple of offroading adventures to see if anything damaged the filter.
Old 01-21-2012, 11:59 AM   #5
wesb1023's Avatar
I have had this installed for about two weeks now....but no off roading yet.
No issues so far.
Old 01-21-2012, 02:35 PM   #6
Texasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud ofTexasdynaryder has much to be proud of
Texasdynaryder's Avatar
Texasdynaryder's Tacoma Gallery
I dig this a lot... Much less mess!!
Old 01-21-2012, 02:40 PM   #7
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
where did you buy this from?
Old 01-21-2012, 05:28 PM   #8
wesb1023's Avatar
Summit Racing Equipment Part # TRD-1113 Price $55.95
Old 01-21-2012, 05:54 PM   #9
thanks
Old 01-21-2012, 08:53 PM   #11
REALLY!!
mrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shed
Air Force: F-22 Crew Chief
mrp192's Tacoma Gallery
how much slack do you have in the hose still?
Old 01-21-2012, 09:12 PM   #12
caffeine nicotine gasoline
livel0veryde is on a distinguished road
livel0veryde's Avatar
livel0veryde's Tacoma Gallery
Looks good iv been thinking about getting one of thies.
Old 01-22-2012, 06:03 AM   #13
wesb1023's Avatar
Originally Posted by Norton View Post
Very nice, OP!
It still uses stock filters right?
Yes, still uses factory filters.
Old 01-22-2012, 06:24 AM   #14
wesb1023's Avatar
Its not terrible I guess, I kind of wanted it to look a bit better. You can order longer hoses or shorter hoses. I called to see if I could just shorten these, and trans dapt said that I needed to carry them to a local place that makes industrial hoses, due to a special tool used to install the ends.
Old 01-22-2012, 06:30 AM   #15
twfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shed
Army: Engineer's
twfsa's Tacoma Gallery
I like it, I seen another post where the filter relocation kit was mounted on the frame rail passenger side, didn't say if it was necessary to remove the skid plate. I just hate to think of changeing oil with that filter mess.
Do you think that if the skid were cut the filter could be removed without removeing the skid plate.
Old 01-22-2012, 07:13 AM   #16
wesb1023's Avatar
Yes, it could be changed with the skid plate on with or without cutting the plate. However there is a pretty good amount of oil that runs out of the lines after removing it. Probably gonna make about as much of a mess as it does with the filter on the engine. If removing the skid plate is a big deal I would just choose another mounting location like in the fender well, there is plenty of hose length to get it out of the way of anything.
Old 01-22-2012, 09:06 AM   #17
Army: Engineer's
I think I may try the relocation kit, as you have it located useing a plastic 2 liter bottle to catch the filter and excess oil in the lines,as the filter drops.
Old 01-22-2012, 04:53 PM   #18
x2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shed
x2468's Avatar
x2468's Tacoma Gallery
Any way to mount up by the valve covers so you can change it by popping the hood.
Old 01-22-2012, 07:02 PM   #19
wesb1023's Avatar
Im sure you could mount it anywhere the hoses will reach. You could also purchase hoses up to 72" long if you needed to put it somewhere special.
Old 01-23-2012, 09:10 AM   #20
defleppardsg is on a distinguished road
defleppardsg's Tacoma Gallery
Do you have to add more oil w/ each oil change now? Since you've got 60in of extra tubing now? Are there any other issues with relocating your filter like this?
Oil filter relocation kit? mrp192 1st Gen. Tacomas 27 05-06-2014 05:53 PM
Best Oil Filter Relocation Kit wesb1023 1st Gen. Tacomas 5 10-21-2011 04:54 AM
Oil Filter relocation and distance Siebler 4 Cylinder 1 09-29-2011 08:50 PM
Oil filter relocation kit 04 Tacoma blitz10 1st Gen. Tacomas 1 08-13-2011 07:39 AM
oil filter relocation paul's08 2nd Gen. Tacomas 4 04-29-2011 01:52 PM
