4 wheel drive on a 98 tacoma with locking hubs
Old 01-24-2012, 07:38 PM   #1
tenn [OP] tenn is offline
tenn is on a distinguished road
tenn's Tacoma Gallery
i have a 98 tacoma 4x4 with manual locking front hubs. i want to know if the truck "pulls" with all four wheels when the 4 wheel drive is on. or how many wheels pull.
Old 01-24-2012, 07:39 PM   #2
Banned
If you have open diffs you have 2 tires with traction at all times.
Old 01-24-2012, 09:27 PM   #3
Cvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shed
Cvd2312's Tacoma Gallery
If you have 4wd engaged, but the manual hubs are free (not locked in) then you are only pulling with the back wheels. You must engage 4wd and lock in the hubs in order to pull with all 4 wheels.
Old 01-25-2012, 06:56 AM   #4
magog45 has much to be proud ofmagog45 has much to be proud ofmagog45 has much to be proud ofmagog45 has much to be proud ofmagog45 has much to be proud ofmagog45 has much to be proud ofmagog45 has much to be proud ofmagog45 has much to be proud of
magog45's Avatar
magog45's Tacoma Gallery
There is no such thing as an out of the box 4 wheel drive Tacoma, the basic 4x4 pulls with just 2 wheels when 4 wheel drive is engaged and a Tacoma with the rear locker pulls with just 3 wheels. You need to install a locker in the front for both front wheels to pull when the hubs are locked and the transfer case is in 4hi or 4lo.
Old 01-25-2012, 02:23 PM   #5
MowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shedMowTaco is one of the sharper tools in the shed
MowTaco's Avatar
MowTaco's Tacoma Gallery
Nuh uhhhh....
A-FUCKING TRAC!
Old 01-25-2012, 05:41 PM   #6
so on a 98 tacoma with locking front hubs, will the truck pull with 4 ?
Old 01-25-2012, 05:42 PM   #7
so it can pull with 4
Old 01-25-2012, 05:52 PM   #8
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
on flat ground with traction to all four wheels yes. with open differentials the diff will send power to the wheel with the least traction. meaning if somehow 2 of the wheels one front one rear were off the ground only 2 would spin because of open differentials. with a locker in the rear the rear 2 wheels pull with the front wheel with least amount of traction
Old 01-25-2012, 06:38 PM   #9
sorry for being dense. but even tho there are manual locking hubs in the front it still has a open diff and will only pull with 1 in the front? i thought if you had to manually lock them in then it would pull with both front tires at the same rate. it seems like it does bc trying to turn with it in 4x4 is a pain. wouldnt that mean that they were not working independantly from one another?
Old 01-25-2012, 06:41 PM   #10
twfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shedtwfsa is one of the sharper tools in the shed
Army: Engineer's
twfsa's Tacoma Gallery
Probaby hard to turn with the hubs locked and on dry concrete.
Old 01-25-2012, 06:44 PM   #11
The Welfare Cadilac
Max-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shed
Max-4_Yota's Avatar
Max-4_Yota's Tacoma Gallery
Yes an open diff will only pull with 1 tire (the one with least traction). If your driving on flat ground it will be pulling with both but once you get in some uneven terrain the one with least resistance will pull.
And DO NOT drive in 4x4, on a hard dry surface (pavement)
Old 01-25-2012, 06:46 PM   #12
but will the tires always rotate at the same speed like in a locking diff?
Old 01-25-2012, 06:50 PM   #13
Dan
YotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shed
YotaDan's Avatar
YotaDan's Tacoma Gallery
Guessing your trying to turn on pavement? If that is the case, then both tires have full traction and steering will be very stiff. Since both tires turn and are traveling close to the same speed, they are fighting each other within the differential as to where to send the power until one tire has less traction. Don't use 4x4 on pavement.
Old 01-25-2012, 06:50 PM   #14
The Welfare Cadilac
Max-4_Yota's Avatar
yes, no matter how uneven the terrain is with a locked diff both wheels will spin at the same rate.
Old 01-25-2012, 06:52 PM   #15
let me know if this is right. open- means tires spin independantly so on flat ground power is distributed equally. on uneven ground one with least traction gets more power and therefore will spin and the one with contact will get no power and you will still be stuck. with locking- tires always spin at same speed, so if one tire is off the ground and one is not, the one in contact will still pull and bc they spin equally the one off the ground should only spin at the same rate as the other on
Old 01-25-2012, 06:54 PM   #16
ok. do all manual locking hubs have locking diff?
Old 01-25-2012, 06:54 PM   #17
Dan
YotaDan's Avatar
For all intents and purposes, that is correct.
Old 01-25-2012, 06:56 PM   #18
Dan
YotaDan's Avatar
The hub just connects the axle to the wheel. By unlocking the hub the wheels are able to spin freely from the rest of the drive train. Since in 2wd there is no reason to be turning the rest of the 4wd drive train, you will get better mileage and less wear and tear.
Old 01-25-2012, 06:58 PM   #19
so my particular truck has locking diff and will better pull me out of mud/snow? as long as the hubs are locked in and 4x4 is engaged with the gearshift
Old 01-25-2012, 06:59 PM   #20
Dan
YotaDan's Avatar
You have a factory rear locker?
Tacoma 99 Manual Locking Hubs Set yoda1999 1st Gen Tacoma Marketplace 11 11-05-2011 02:17 PM
servicing 1999 tacoma locking hubs semievolved Technical Chat 0 10-30-2010 09:54 AM
98-98 TRD elec. locking differential with 411 gears! Bone Buster Buy / Sell / Trade 1 08-05-2009 05:45 PM
FS: WARN Manual 4 wheel drive hubs for Tacoma. Nexxus6 Buy / Sell / Trade 0 12-18-2008 10:20 PM
Locking Hubs issue? Front drive shaft spinning, but no wheels! GURU's HELP! daward Technical Chat 10 06-24-2008 08:49 PM
