Nocking noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by GATORTACO92, Jan 26, 2012.
  1. Jan 26, 2012 at 7:45 PM
    GATORTACO92
    GATORTACO92 [OP] Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    i know this has most likely been posted but i can't find it. i have a 2001 tacoma dbl cab 4x4 with 215k miles. i have a 3" spacer and AAL. this has been happening with in the past year. I've had the lift for almost year n' half give or take. I've been having some weird popping noises in the front end of my truck...it only happens when i go over bumps or curbs. i figured it could be the bushings on the control arms and thus allowing them to shift side to side...or i need a new suspension upgrade? please help i have no idea what this could be. i also have a really bad shaking problem when driving at normal speeds from stop to 70mph. and also the well know shaking when slowing down. i have replaced rotors, pads 4 times now and I'm tired of it. i have also changed the calipers on the last time i changed rotors and pads. please give me your knowledge! oh i also just recently replaced the steering rack and tie rods. i know i need to get the energy bushings.
    Edit: its really any type of bump that causes the suspension to compress is better way of putting it. it occurs at low speeds but i heard it the other day hammered how on the highway doing....80ish:/
  2. Jan 26, 2012 at 7:49 PM
    Lost_Humanity
    Lost_Humanity Bad decisions make great stories.
    Seattle
    It's a Toyota.
    Bumper Dent Mod
    "Knocking."
    That's all the knowledge I have. Sorry. Although at 215K miles and a spacer lift you might want to check your shocks/springs. If they're original, you might be putting a lot of stress on worn-out parts.
  3. Jan 26, 2012 at 7:54 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    sounds like your coil over top plates
  4. Jan 26, 2012 at 7:57 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    John
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    sounds like the knock is ball joint related and the shaking is your worn out steering rack bushings.....just replaced mine today no more shaking while going or braking.....it is cheap and simple to do energy suspension make a kit for our trucks. took me about 1 hour.....
  5. Jan 26, 2012 at 7:58 PM
    sir1123
    John
    Charleston
    sh%t i didnt read all the way through.....but ya they worked for me
  6. Jan 26, 2012 at 8:16 PM
    GATORTACO92
    Alex
    Hoover, Al
    so maybe new UCA's, ball joints, bearings (while I'm at it), front suspension...im sure all parts are stock. i bought it used, it was traded in the day i bought it...2-3 years ago now.
  7. Jan 26, 2012 at 8:32 PM
    sir1123
    John
    Charleston
    ya you might as well...def worth the money if you got it....go with new coils new shocks and get your b joint replaced....and ditch the coil spacers....if possible get some eibachs or ome coils and some billy shock if it just a dd with mild offroad use.
  8. Jan 26, 2012 at 8:34 PM
    sir1123
    John
    Charleston
    and i dont think ucas are a necessity unless you have alignment issues or to just get better performance from the lift.
  9. Jan 27, 2012 at 9:04 AM
    GATORTACO92
    Alex
    Hoover, Al
    mostly better performance for lift.
  10. Feb 13, 2012 at 5:57 PM
    pickuptruckguy
    pickuptruckguy Well-Known Member
    SoCal
    04 Doublecab 4x4
    any updates on this? what did you find out?
  11. Feb 13, 2012 at 7:11 PM
    GATORTACO92
    Alex
    Hoover, Al
    yes, sorry. it turns out that the cv axle was snapped at both joints:cool:
    never thought to look at that but i did check it to make sure and it seemed okay when i did. but i got the new cv axle today and i will be converting to manual hubs:D
  12. Feb 13, 2012 at 7:39 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    This may be a very dumb question, but how did you notice the CV axle was bad? Do you have any pictures of what it looked like? The reason I ask is I've been having the same problem for a while now. It makes a clunking/knocking noise while going over any bump, mainly at low speeds. I poked my head under there but didn't notice anything out of the ordinary, but I don't really know what to look for.
  13. Feb 13, 2012 at 11:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    put it in 4x & you'll know soon enough....;)
  14. Feb 14, 2012 at 12:24 AM
    ffirg
    mike
    Anchorage, Alaska
    haha well that settles that. my 4wd works fine. I'll hop under there again when I can and take another look. Maybe rack bushings?
  15. Feb 14, 2012 at 8:50 AM
    GATORTACO92
    Alex
    Hoover, Al
    I rotated the wheels like it was going down the road. Passenger side was easy to rotate. But driver side would turn 180 degrees then "seize" up until I forced it to rotate and then 180 degrees again it did the same. While doing all of this I was watching the cv. It would do a wobble motion or a unbalanced motion depending on how fast you turned it. I figured wen going at highway speeds or when ever it is turning it is cause the wobble feeling going down the road. Sorry if I repeat myself, I'm doing this on my iPhone. I will take pictures when I get off. They won't be good cause I will be going to school shortly after I get off.
  16. Feb 14, 2012 at 7:26 PM
    GATORTACO92
    Alex
    Hoover, Al
    pics. i have a video of the noise. it was taken at dark about 10 min again.
    it looks like a normal driveshaft until you actually see it in motion. with the wheel off and on stands.
  17. Feb 18, 2012 at 9:05 PM
    GATORTACO92
    Alex
    Hoover, Al
    sorry, been busy with work. I'm fixing cv, and wheel bearing tomorrow so ill post and let you know if that solves it. i changed the rack and not the bushings and it is perfectly fine. doesn't move or anything...i changed rack roughly around 200k miles i believe, I'm gonna start a log of when i change things from now on.
