diff lock actuator
Old 02-04-2012, 08:56 PM   #1
caesarspalace is on a distinguished road
caesarspalace's Tacoma Gallery
diff lock actuator
Ok, need some advice. My elocker stopped working, so I attempted to do this rebuild: http://personalpages.tds.net/~thompson_wp/tacoma/locker.htm
The die-cast aluminum cover on the backside of the actuator was so corroded that when I went to pry the actuator off the diff, it broke around the shaft. It is beyond repair.
Toyota dealer quoted me over $1200 for new actuator assembly.
I have searched online parts discounters but no luck.
The auto wreckers, have diffs come in with lockers, problem is they donít want to take them off the diff and sell them separately. $500 or more for a complete diff. Plus, I canít be sure theyíre working properly, or if Iíll be able to get them off without breaking either. I canít just swap carriers, I need to the actuator off and put it on my diff because I did a gear swap.
What are people doing who encounter this problem?
Any one out there selling rebuilt actuators?
Any suggestions?
Old 02-04-2012, 09:08 PM   #2
DOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shedDOUBLLD is one of the sharper tools in the shed
DOUBLLD's Avatar
DOUBLLD's Tacoma Gallery
I don't believe there is a "rebuilt" actuator available. New or used is ur best bet
Old 02-04-2012, 10:30 PM   #3
mall crawler
Rebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shed
Rebel Taco 22's Tacoma Gallery
I would try to talk the places into letting you have the actuator. If they wont let you then I guess you could buy the whole assembly and then sell the carrier? That might work
Old 02-16-2012, 06:23 AM   #4
Afwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shedAfwrestler1986 is one of the sharper tools in the shed
Afwrestler1986's Avatar
Air Force: B-52 Crew Chief/ Ground Radio MX/ LC-
Afwrestler1986's Tacoma Gallery
Someone made a cable conversion(downey made it I think) I cant find anything either. I may resort to building my own actuator. I refuse to pay that much for a small motor.
Old 02-16-2012, 08:45 AM   #5
Unfortunately Downey went out of business in 2008. I managed to find a near new used actuator in Texas for a reasonable price.
Old 02-16-2012, 10:38 AM   #6
Lube: It's the key to penetration.
STLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shedSTLharry is one of the sharper tools in the shed
STLharry's Avatar
EMS: Charlotte VRS: EMT/Driver
STLharry's Tacoma Gallery
Lucky lucky.
Toyota labels this a 'non-servicable' part so they just sell the whole assembly and you cannot get it elsewhere (parts stores) I believe. Good thing you found a used one!
I rebuilt mine last summer because it stopped working. I found crystalised salt on the inside of the casing. Keep an eye on the seal!
Old 02-16-2012, 11:32 AM   #7
I'm aware of Toyota's non sevicable description of this part, but as seen in my first post, there is a rebuild, which I attempted to do, but rear cover plate which is made out of die-cast aluminum crumbled as I took it off the diff. And yes, I'm sure road salt had something to do with it.
Old 04-26-2012, 09:17 PM   #8
Well, I just broke down and bought the E-Racer from Chilkat designs. I will post up pics when I get it.
Old 04-27-2012, 01:53 PM   #9
RTO
FailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shed
FailRated's Avatar
FailRated's Tacoma Gallery
Sub'd
I want to hear about the E-Racer when you get it installed. Keep us posted please.
Old 05-02-2012, 06:52 AM   #10
DOUBLLD's Avatar
Anyone lookin for a 1st gen supercharger? Has 40k on it looking to get 1,500 plus shipping
Old 05-02-2012, 08:43 AM   #11
Maybe make a thread here:http://www.tacomaworld.com/forum/1st...a-marketplace/
Probably get better coverage. Be sure to post pic and your location as well.
Old 05-02-2012, 08:53 AM   #12
DOUBLLD's Avatar
I will but in Florida now so when back from vacation I'll do that
Old 05-09-2012, 11:36 AM   #13
DOUBLLD's Avatar
Here is a picture an I posted it in the market place
Old 05-11-2012, 03:50 PM   #14
Alright, so i got the kit on tuesday and have been waiting for a nice day to do the install. I will be the first to admit that i was a bit worried about the 600 dollar price tag, i mean really? 600 bucks for some aluminum, a cable and a lever? No way. But when i opened the box and saw what they sent, i was really impressed. The whole kit is very well put together.
The hardest part for me was figuring out how to mount the lever and route the cable. I think the lever assembly could be smaller for our already small trucks.
The instructions they send are great. And they tell you that you will end up taking the actuator out several times.......yup. You may get lucky, not likely. When you are trying to rig it all up, it will save a whole lot of time with two people. One to actuate the lever, and one under the truck trying all of the holes and positions on the actuator. i did the whole install in a couple hours. I still have not routed the cable in the cab the way i would like and still have to mount the lever. But all in all it is a really good setup. Everything is solid and not going to break on a whim.
I will poat up pics when i figure it out from my phone.
Old 05-13-2012, 09:53 AM   #15
Old 05-13-2012, 05:30 PM   #17
Like i said, i didn't get around to mounting it yet, but that is where it is going. The cable willgo out the soft plug on the back of the cab. (in the cubby hole)
WTB diff lock actuator caesarspalace Buy / Sell / Trade 0 02-06-2012 10:03 AM
Is this a problem with my door lock actuator? Madjik_Man 1st Gen. Tacomas 6 01-16-2012 02:04 PM
Is this a problem with my door lock actuator? Madjik_Man 1st Gen Tacoma Marketplace 1 01-16-2012 09:57 AM
WTB Lock Actuator Chen 1st Gen Tacoma Marketplace 2 10-27-2011 04:27 PM
Looking for a door lock actuator BrianPK Buy / Sell / Trade 4 08-30-2010 11:14 PM
