'Hiccup' problem with K&N cold air intake! fixable?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Soccerdallin, Feb 17, 2012.
  1. Feb 17, 2012 at 12:59 AM
    Soccerdallin
    Soccerdallin [OP] Well-Known Member
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    Magnaflow exhaust w/ tip, 18" Rockstars, AEM CAI, TB Spacer, Billet Grille, Limo tint, LED tail lights, 20,000k HID headlights + Blue LED strips, debadged, Jl Audio Subs in custom box, 6X8 speakers with tweeters, sony deck.
    Hello!
    I installed a K&N cold air FIPK and a TB spacer as well like a week ago. I love the noise and extra power I've gained and better MPG, but sometimes when I'm floorin' it, the engine seems to studder. This doesn't happen often luckily. I might just take it in to the shop.. love the products but don't like the occasional 'hiccups' I get when I'm accelerating fast. Kind of seems to counteract the point of buying it....right? haha
    Thanks! :D
    1997tacomav6 likes this.
  2. Feb 17, 2012 at 1:28 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    maybe you are running too lean now?
    with the intake and a throttle body, you get the increased air flow, but your injectors are still flowing at the same rate...
    did you disconnect the battery when you installed the intake? i think the instructions tell you to... it resets your ECU and with the new air/fuel ratio, it will reset itself...
    i had a similar issue when i first put my CAI and resetting the truck stopped the issues...
  3. Feb 17, 2012 at 1:32 AM
    Soccerdallin
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    Hmmm..pretty sure I disconnected the battery while I installed everything, but maybe I'm wrong.
    I'll disconnect the battery for a while and then connect it and hope it helps.
    I've read that the MAS could have something to do with it, but I made sure that it's secure.
    I'll try that out and hope it works.
  4. Sep 19, 2018 at 12:02 PM
    Blato
    Blato Member
    2016 TRD Sport Double Cab - Manual
    2016 Tacoma TRD Sport – Manual TRD Cold Air Intake Magnaflow Exhaust Sway Bar Pedal Commander Train Horns Morimoto HID Upgrade Hidden Multicolor LED Light Bar Drilled and Slotted Rotors Tailgate Pop & Lock Toyota OEM Cargo Lighting Sequential Side Mirror Lights Undercover Ultraflex Tonneau HAI Cable Assy. with Wireless/HDMI/RCA Screen Mirroring Kit (Phone to Display) Speed Override Safety Switch for Display LED Interior and Exterior Lighting
    I am having a similar issue on my 3rd Gen Tacoma after installing a K&N CAI. I re-installed my original intake yesterday and the problem stopped. I heard a dirty MAF sensor could cause it as well as an air leak. Did you ever find a solution to it?
  5. Sep 19, 2018 at 12:05 PM
    jbrandt
    jbrandt Made you look
    Justin
    El Dorado, CA (NOT El Dorado Hills)
    '04 TRD Tacoma 4x4 DC
    Kings, J59's Total Chaos UCAs Custom skids Sticker mod
    OP is from 2012, lol...
    If you have issues with your 3rd gen, try posting in the 3rd gen forum...
    Sperrunner likes this.
  6. Sep 20, 2018 at 4:24 AM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    John
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    Try it without the red spacer, never had that issue ever and I put mine on new 570,000 miles ago,
    FishnTx likes this.
  7. Sep 20, 2018 at 12:31 PM
    Blato
    Blato Member
    Which red spacer are you talking about? I switched between the stock and K&N 3 times to see if I made an installation error (maybe an air leak somewhere) but the issue is still there. I don't remember seeing a red spacer. Also, my kit is the polished aluminum version so not sure if that makes any difference. Thanks for helping.
  8. Sep 20, 2018 at 2:21 PM
    1997tacomav6
    John
    Denver
    The red spacer by the throttle body
  9. Oct 1, 2018 at 4:48 PM
    Soccerdallin
    Dallin
    Arizona
    04 SR5 3.4L V6 4X4
    My check engine light kept coming on with the k&n so I switched to an oil free cai and for whatever reason it helped the "hiccup." haha not sure why, but 5 years later it still works great! Going o be selling the truck next year and getting a newer one..
