Total chaos weld on spindle gusset questions
Old 02-20-2012, 09:00 PM   #1
TRD OFROAD
pegcitytacoma is on a distinguished road
pegcitytacoma's Avatar
pegcitytacoma's Tacoma Gallery
Talking Total chaos weld on spindle gusset questions
Does anyone have the total chaos weld on spindle gussets? I would like to get these but I can't find info about the prep process of the spindles if any other than cleaning up the spindle with a grinder with a wire brush wheel. Just to let you know I have a 2003 4x4 taco and am doing work on the front end soon but don't have a lot of experience with the front end of a 4x4. Once I have the spindle out can I just weld the gusset on or is more disassembly needed and if so what and how?? Any help here would be great
Old 12-24-2012, 03:13 PM   #2
ckblum is a glorious beacon of lightckblum is a glorious beacon of lightckblum is a glorious beacon of lightckblum is a glorious beacon of lightckblum is a glorious beacon of lightckblum is a glorious beacon of light
ckblum's Tacoma Gallery
Same question, too lazy to make another thread. Hopefully someone answers this time.
Old 12-24-2012, 03:19 PM   #3
Gelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shedGelo760 is one of the sharper tools in the shed
Gelo760's Tacoma Gallery
Yes some people do it on the truck . Mine were taken off .
Old 12-24-2012, 03:39 PM   #4
05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed05tacoSPORT is one of the sharper tools in the shed
05tacoSPORT's Avatar
05tacoSPORT's Tacoma Gallery
Pull them. Wire wheel clean them. Weld them. Re install them.
Old 12-24-2012, 03:40 PM   #5
Old 12-24-2012, 03:45 PM   #6
Ritchie is on a distinguished road
Ritchie's Tacoma Gallery
I have an '03... I removed the wheel and welded in place. I used a MIG and stitch welded. I don't receommend using an ARC machine.
Hope this helps you out.
Later.
Old 12-25-2012, 06:43 AM   #7
wolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud of
wolfgang123's Avatar
wolfgang123's Tacoma Gallery
Should all the bearings and seals be removed to prevent damage?
Old 12-25-2012, 07:17 AM   #8
Not necessary.
If you have OEM UCA's, be sure to shield the ball joint.
Later.
Spindle gusset question Redgrom Suspension 8 01-06-2012 07:44 PM
Total Chaos kingtaco 2nd Gen Tacoma Marketplace 16 09-27-2011 05:34 AM
Bent weld on gusset, fix or return ? Razorecko 2nd Gen. Tacomas 4 06-24-2011 09:00 PM
Spindle gusset trade for your stock s7racing Long Travel Suspension 0 02-13-2011 09:34 PM
Total Chaos Spindle Help devil01 Suspension 21 11-08-2009 02:45 PM
