231mm brake upgrade PROBLEM on 2001 Taco dbl cab
Old 03-20-2012, 04:25 PM   #1
baloo [OP] baloo is offline
baloo is on a distinguished road
baloo's Tacoma Gallery
Ran into a problem upgrading my 2001 Toyota Tacoma dbl cab to the 231 mm Tundra Brakes. The Tacoma uses a banjo fitting, which as I read through the many write-ups didn't see any mention of. In fact one writeup on t4r.org showed the 231mm install with the banjo fitting.
In either case, I am kinda stuck on what to do and wanted to see what others have done. Don't want to have to put back together and double work, so without a vehicle till I figure this out.
This is the old caliper
This is the bolt for the banjo fitting;
This the the new caliper, which generally uses a hardline fitting;
Any suggestions?
Old 03-20-2012, 10:30 PM   #2
Stealth Custom Series™
SCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shed
SCSPerformance's Avatar
SCSPerformance's Tacoma Gallery
from some of the write-ups i've read:
Modifications required:
-Bending the dust cover / disk shield.
-Drilling out the end of the banjo bolt approx 1/8”-1/4” deep.
2011 Dbl Cab SB V6 Brake Squeal Cypherian 2nd Gen. Tacomas 38 08-27-2013 10:55 AM
1st Gen (2001 Sr5 Reg. Cab) Door Speaker + Tweeter Upgrade bluebr65 Audio & Video 3 03-20-2012 09:29 AM
18x9's on a 2001 TRD dbl cab ebayollis 1st Gen. Tacomas 3 03-10-2012 09:24 AM
2001 PreRunner dbl cab lift tacomaprerunner 1st Gen. Tacomas 40 01-01-2010 11:44 PM
2001 DBL cab,TRD,4X4 want better ride USMCVet 1st Gen. Tacomas 2 10-03-2009 09:10 PM
