"Slightly" cracked exhaust manifold - replaced
Old 03-25-2012, 09:36 AM   #1
Drewski [OP] Drewski is offline
Drewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shedDrewski is one of the sharper tools in the shed
Drewski's Avatar
Drewski's Tacoma Gallery
I knew that there was a crack in my exhaust manifold on my '99 3ZR; actually I knew to look for it thanks to all the posts I read on TW. There has been a noticeable: loss of power, drop in MPG, increase in noise - and I don't mean a good sound either. I haven't smelled any exhaust leaks in the cab or gotten any CELs, but it seemed that the crack has steadily been getting worse. Or as ******* Toyota diagnosed it, "a leaky exhaust gasket."
My suspicions were confirmed when I took this picture (finally removed that oddly complicated air intake system):
I had been waiting for the group buy on the Doug Thorleys, but I didn't know when that was going to come together, so I went ahead and got the factory kit from Nix 99 in WA. FYI, it took 4 days to Chicago. Obviously not quite as nice as a set of SS long tubes, but looks better than the stock cast piece:
So I pulled the stock part off yesterday, which ended up being a little more of a pain than I figured. Of course, if I had to do it again, I could definitely knock it out in an hour or so. Anyway, I pulled the stock piece off and noticed that the cracks (plural!) were more serious than I thought, and went around the entire manifold. It was only a matter of time before the whole thing cracked completely.
A little deconstruction video here, demonstrating exactly how cracked the manifold was.
http://www.youtube.com/watch?v=SDxx2vC5Uq8
You can see by the profile shot just how bad the exhaust was leaking. Note the color of the metal; the dark areas obviously have been leaking exhaust.
So I installed the new part and hooked everything up. Before I reconnected the airbox though, I ran some TB cleaner through the air tube to clean out the TB. Apparently it hasn't been cleaned in quite a while. I backed the truck out of the garage a little bit and blew out quite a bit of white smoke. The alley looked like it was being fogged for mosquitoes.
I'm looking forward to checking the mpg over the next few fillups to see if the new manifold helps. I took the truck for a short spin, and the sound is much better. No more of that "leaky air compressor" sound. There seems to be a bit more of a low rumble, or maybe that's just how it should sound. The manifold has likely been cracked since I bought the truck last October, so I've never really heard a "good" exhaust sound from this truck anyway. At least the sound no longer detracts from the otherwise tough look of the stock truck.
I'm sure the header would sound better, but I didn't want to wait any more. And I doubt the extra couple hp I might get would make much of a difference in my life. The tach almost never sees over 2k anyway.
Old 03-25-2012, 11:16 AM   #2
BTO BTO is offline
BTO is a name known to allBTO is a name known to allBTO is a name known to allBTO is a name known to allBTO is a name known to allBTO is a name known to all
BTO's Avatar
Army: 3rd Infantry Division
BTO's Tacoma Gallery
Is it possible the stock manifold got over heated? It looks burnt.
Old 03-25-2012, 11:43 AM   #3
To secure peace, is to prepare for war
TacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shed
TacomaJPP's Avatar
TacomaJPP's Tacoma Gallery
Good job. My 1997, 2.7 did the same thing. Heck, nearly every Pre-2000 2.7 on the road ticks at very red light if you listen closely enough.
Old 03-25-2012, 07:40 PM   #4
n0ms is on a distinguished road
n0ms's Tacoma Gallery
The 2.7 engine is just loud,mine runs great,replaced what has been needed when needed.
Wonder if taking the clutch fan will quite it down a bit?
Old 03-28-2012, 07:05 AM   #5
Drewski's Avatar
I have only just filled up a tank of gas so I don't know if there will be any difference in mpg. I sure hope so, since I drive about 45 miles per day and gas is pushing $5/gal here in Chicago. Every mpg helps! However, I have noticed: the truck is now a lot quieter (duh), it accelerates much better off the line, and it idles a lot lower too - almost too low, like it is close to stalling. Ok, not quite that bad, but I occasionally pop the trans into neutral at stop lights to eliminate the low RPM rattles. I'm not complaining though. It is running a lot smoother since the new manifold install / TB cleaning. I can't say if it's better than the stock *uncracked* manifold though, as I think mine has been cracked since I bought it.
Old 03-28-2012, 11:44 AM   #6
TW's Official anti body-lift pundit
TacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shed
TacoMX's Avatar
EMS: Paramedic
TacoMX's Tacoma Gallery
My 97's manifold was cracked in almost the same way/location,
Replaced mine with an LCE header.
Manifold Cracked! NoCrash 1st Gen. Tacomas 7 01-20-2015 08:04 PM
2.7 Exhaust Manifold advice? JeepRecoveryCrew Performance and Tuning 1 02-20-2012 07:36 AM
Questions: head gasket and cracked exhaust manifold- 97 3RZ sgtlethargic Performance and Tuning 17 08-25-2011 12:59 AM
2.7 exhaust manifold drshirk 1st Gen. Tacomas 7 08-08-2010 07:57 PM
cracked exhaust manifold DaytonLax14 1st Gen. Tacomas 8 12-20-2009 06:47 PM
