Ball Joint Problems
Old 04-03-2012, 07:46 PM   #1
scalfee90 [OP] scalfee90 is offline
scalfee90 is on a distinguished road
scalfee90's Avatar
scalfee90's Tacoma Gallery
Ball Joint Problems
I'm having issues with my lower ball joints. I have replaced the driver side once and now its about 3 or 4 months later and its about to pop again. Is there any suggestions to permanently fix ball joint problems. I actually looked at greasable Moog ball joints. I would appreciate some help i don't want it to come apart while goin 70 and surely die on my way to work.
Old 04-03-2012, 07:47 PM   #2
04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed
04LTtacoma's Avatar
04LTtacoma's Tacoma Gallery
Go with the Moog lower ball joints. I just recently replaced my lower ball joints with Moog. They hold up to a lot of abuse and the ball joints are greasable..
Old 04-03-2012, 07:47 PM   #3
Your Unique, Just Like Everyone Else
TacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shedTacoBran is one of the sharper tools in the shed
TacoBran's Avatar
TacoBran's Tacoma Gallery
How do you know when you have lower ball joint issues?
Old 04-03-2012, 07:49 PM   #4
scalfee90's Avatar
Actually with mine it sounded dry and no matter which way you turn or bumped it you could hear it squeaking like a ford explorer!
Old 04-03-2012, 07:50 PM   #5
scalfee90's Avatar
Well problem solved I guess. Where is my best price on some?
Old 04-03-2012, 07:51 PM   #6
04LTtacoma's Avatar
Jack the front of your truck off the ground then take a crowbar and wedge it between the LCA and ball joint. If there is lots of play in the ball joint then you need new ones.
Old 04-03-2012, 07:52 PM   #7
04LTtacoma's Avatar
I bought mine from an alignment shop for $110 a piece. You might be able to find them cheaper online.
Old 04-03-2012, 07:53 PM   #8
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
advance auto order online use a discount code. just google for discount codes. has saved me a ton of money
Old 04-03-2012, 07:53 PM   #9
scalfee90's Avatar
Awesome, thanks buddy
Old 04-03-2012, 07:56 PM   #10
04LTtacoma's Avatar
If you purchase the greasable lower ball joints be sure to buy a pack of zerk fitting because the ball joints don't come with grease fittings.
Old 04-03-2012, 07:57 PM   #11
scalfee90's Avatar
Well dang! I would of went home without them too!
Old 04-03-2012, 07:59 PM   #12
Señor member
Cr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shedCr250jumper is one of the sharper tools in the shed
Cr250jumper's Avatar
Cr250jumper's Tacoma Gallery
Its a lot easier if you jack up the truck by the arm, then put the crow bar under the tire and pry up. The ball joint will lift up and down in the arm if its loose. No need to wedge anything in your $2400 LCA's
Rock auto has them for ~$44 each
Old 04-03-2012, 08:05 PM   #13
04LTtacoma's Avatar
I went wheeling last Saturday... Friday I had the truck in the alignment shop. They told me my ball joints were about to fall apart and they also showed me. I called every local toyota dealership to see if they had lower ball joints in stock unfortunately no one had any ball joints in stock so I decided I order a set through the alignment shop since the ball joints would show up in a few hours. So basically I only had a day to install those lower ball joints in order to go wheeling the next day. If I had gone wheeling without the new lower ball joints my truck would be toast. So basically I would either pay $88 for a set of ball joints and not go wheeling or pay $220 and go wheeling.
Old 04-03-2012, 08:16 PM   #14
TacoBran's Avatar
thanks guys
Old 04-03-2012, 08:39 PM   #15
scalfee90's Avatar
Part Numbers for Moog Greasable.
MOOG Part # K90258
MOOG Part # K90259
Old 04-03-2012, 09:31 PM   #16
Señor member
Damn, pay to play
Old 04-11-2012, 06:07 PM   #18
hossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud of
hossmaster's Tacoma Gallery
1/4", 1/8", or metric zerk?
Old 04-11-2012, 06:10 PM   #19
04LTtacoma's Avatar
Not to thread jack, but does anyone have the moog outer tie rods?
Lower Ball Joint Toy4Life 1st Gen. Tacomas 12 03-10-2011 05:52 PM
Ball Joint Boot HELP!!! jayandcourt 2nd Gen. Tacomas 4 09-30-2010 01:47 PM
ball joint?? red neck toy General Automotive 4 04-29-2010 08:40 PM
ball joint help kris219 Suspension 1 04-18-2010 05:53 PM
Better Ball Joint help?? tmolina 1st Gen. Tacomas 2 12-18-2009 08:10 PM
