What's your 1st gen v6 temp?
Old 04-06-2012, 05:59 PM   #1
yoTaco98 [OP] yoTaco98 is offline
yoTaco98 is on a distinguished road
yoTaco98's Tacoma Gallery
I was just wondering what your temperature needle reads on your V6 1st Gens once you're at operating/idle temp?
The picture shows my temp needle on my 98. My needle consistently hangs strong at dead center, but every other vehicle/truck I've ever owned has had the temp needle just slightly below center.
So my question is: Is my needle location normal?
If you could check you 1st gen's (I have a 98 v6 4x4), and tell me what your temp gauges look like, I'd really appreciate it.
Old 04-06-2012, 06:14 PM   #2
The Rembrandt of Rattle Can
Madjik_Man's Avatar
Madjik_Man's Tacoma Gallery
That's exactly how my temp and idle are on my 98. Perfectly normal
Old 04-06-2012, 06:17 PM   #3
PkTaco is a glorious beacon of lightPkTaco is a glorious beacon of lightPkTaco is a glorious beacon of lightPkTaco is a glorious beacon of lightPkTaco is a glorious beacon of light
PkTaco's Tacoma Gallery
Might rans a tad high and always has.
Old 04-06-2012, 06:18 PM   #4
v.hey its my Avatar avatar.v
ak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shedak47 is one of the sharper tools in the shed
ak47's Avatar
ak47's Tacoma Gallery
same
Old 04-06-2012, 06:27 PM   #5
Tacomanater is on a distinguished road
Tacomanater's Avatar
Tacomanater's Tacoma Gallery
Mine is dead set in the middle. With the Ultragauge, it is reading about 208-212F.
Old 04-06-2012, 06:56 PM   #6
Awesome.
Glad to hear it's normal.
I'm at 178k now. Almost time to redo the timing belt. Figured I'd do the water pump and radiator flush at the same time. Maybe a thermostat?
Thank you for the quick responses.
Old 04-06-2012, 07:01 PM   #7
ffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shedffirg is one of the sharper tools in the shed
ffirg's Avatar
ffirg's Tacoma Gallery
Mine is also always at dead center. Have not even noticed it going up even when going up large, steep inclines.
Old 04-06-2012, 08:38 PM   #8
I have a problem for your solution…
Snowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shedSnowman is one of the sharper tools in the shed
Snowman's Avatar
Snowman's Tacoma Gallery
My 2.7 is like that too. Had me concerned when I first bought the truck but I asked around here and apparently is normal.
Old 04-06-2012, 10:01 PM   #10
Originally Posted by hayabusa3303 View Post
mine is 185 to 183.5 depends on temp outside.
Electric fans kick in around 195
scan gauge alarm is at 200
How do you know the exact info? Is there a tool that tells me this?
Old 04-06-2012, 10:44 PM   #11
TacomaV6 is on a distinguished road
TacomaV6's Tacoma Gallery
you can always buy one of them temp gauge but get a pod :x or your gonna have to cut a hole somewhere to mount it
Old 04-07-2012, 02:05 AM   #14
Robertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shed
Robertgeejr1's Avatar
Robertgeejr1's Tacoma Gallery
its the same on mine, and listen the gauges that come from the factory and its just about the same with all auto makers are just BASIC. and with time and wear and people would be surprised with the crud that can accumulate at the gauge sensors, they lose accuracy. they would still let you know if the oil low or running hot, just not not pin point.
and as for the cooling system, that is my plans for tomorrow. they changed the belt, water pump 3 month before i got her, but i am changing all the hoses, clamps, thermostat (toyota one) and 8 gallons of distilled water and a flush kit. and really if I am not happy with the way the radiator looks or what comes out, then before it get warm its going to be replaced, its not hard or expensive.
Old 04-07-2012, 04:42 PM   #16
MainahWithaYota is on a distinguished road
MainahWithaYota's Tacoma Gallery
My 04 V6 runs in the same spot.
Old 04-07-2012, 06:40 PM   #17
To secure peace, is to prepare for war
TacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shedTacomaJPP is one of the sharper tools in the shed
TacomaJPP's Avatar
TacomaJPP's Tacoma Gallery
03 V6 the same.
Old 04-07-2012, 06:48 PM   #18
Cvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shed
Cvd2312's Tacoma Gallery
My '97 V6 runs slightly below center
Old 04-07-2012, 07:17 PM   #19
Formally afroman5015
bellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shedbellassaiw10 is one of the sharper tools in the shed
bellassaiw10's Avatar
Army: 31B 1132 MP Co.
bellassaiw10's Tacoma Gallery
00 Runs dead at center unless I'm in traffic thin it might move a centimeter or two ha but mine runs at 198+- a couple on my ultra gauge
Old 04-07-2012, 09:23 PM   #20
Hoyle is a glorious beacon of lightHoyle is a glorious beacon of lightHoyle is a glorious beacon of lightHoyle is a glorious beacon of lightHoyle is a glorious beacon of light
Hoyle's Avatar
Air Force: Commander & Chief
Hoyle's Tacoma Gallery
Dead Center, same as yours..
Good lookin 4x4 v6 1st gen on ebay Shiner 1st Gen Tacoma Marketplace 0 08-31-2011 05:22 PM
FS: K&N for 1st Gen V6 WVTacoma08 1st Gen Tacoma Marketplace 11 08-26-2011 06:11 AM
2nd gen I4 vs 1st gen v6. CollegeTacoma 2nd Gen. Tacomas 42 07-20-2011 04:45 PM
Do all 1st gen V6 have exhaust drone? ywen 1st Gen. Tacomas 4 02-21-2011 03:51 PM
WTB 1st gen double cab v6 5 speed 4x4 mycal Buy / Sell / Trade 16 09-25-2009 01:54 PM
