OME 2.5" Lift, biggest tires I can run?
Old 05-04-2012, 12:16 AM   #1
upgrayedd [OP] upgrayedd is offline
Spelled with two D's. For a double dose of pimp'n
upgrayedd is on a distinguished road
upgrayedd's Avatar
upgrayedd's Tacoma Gallery
Yep, thinking about this lift. 2004 x-tra cab. What tires can I run? Would like 33". TIA.
Old 05-04-2012, 12:22 AM   #3
First Class White Trash
achirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shedachirdo is one of the sharper tools in the shed
achirdo's Avatar
achirdo's Tacoma Gallery
Biggest physically possible to stuff in there? 35s.
305/xx/Rxx
Old 05-04-2012, 12:22 AM   #4
achirdo's Avatar
Lots of cutting required ^^
Old 05-04-2012, 06:36 AM   #5
haddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud ofhaddix has much to be proud of
haddix's Avatar
haddix's Tacoma Gallery
265/75/16 No trimming
255/85/16-285/75/16 Slight trimming
315/75/16 A lot of cutting and welding
Old 05-04-2012, 01:55 PM   #6
upgrayedd's Avatar
Rubbing?
Great. Thanks for the replies.
With 265/75r16. Will I encounter any rubbing?
Old 05-04-2012, 02:00 PM   #7
Kenny Fuckin Powers
jtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shed
jtav2002's Avatar
jtav2002's Tacoma Gallery
Nope.
Old 05-05-2012, 09:23 AM   #9
Taco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shed
Taco76087's Avatar
Taco76087's Tacoma Gallery
as mentioned you can run 285/75/16 on as little as 1'' of lift, all I had to do was trim my pinch weld.
go with the 33's that way you won't want to get bigger tires in a few months
Old 05-05-2012, 04:06 PM   #10
capetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shedcapetaco12 is one of the sharper tools in the shed
capetaco12's Avatar
capetaco12's Tacoma Gallery
33's are doable. 33x10.50s you need to hammer the pinch weld over.
33x12.50s you will need to do a little chop on the fenders. If you do alot of wheeling with the swaybar off you should smash the shit out of the firewall or tub it a tad.
I have OME 881's and the regular leaf In the rear unless you do another shim to move the axle back a half inch. The OME wont center your wheel wells. At full stuff (without bumpstops) You will also rub on the front of the wheel well.
x10.50s
Old 05-05-2012, 04:09 PM   #11
capetaco12's Avatar
If your truck is on the road most of the time you can get away with just the Pinch weld and put counter sunk bolts or just remove the lower ones on your flares.
Old 05-05-2012, 04:15 PM   #12
TacoTuck is on a distinguished road
TacoTuck's Avatar
TacoTuck's Tacoma Gallery
I have a 1.5" OME lift (881's I think) and with 265/75/r16's I have frame rub.
Why is this?
Old 05-05-2012, 04:23 PM   #13
capetaco12's Avatar
Why is this?
Need more backspacing on the rims. IDK what you need for those im bad with metric sizes. But for a 12.50 4" works mint.
Old 05-05-2012, 06:32 PM   #14
TacoTuck's Avatar
I need more back spacing even though they are stock wheels?
Old 05-05-2012, 07:23 PM   #15
upgrayedd's Avatar
I really want to run 15" steelies. Thinking Wheelers HD steels.
And I really want to run 33"s.
I'm running the Slee OME 882's(Arb bull bar). The Dakar's have settled abit...
Any definitive answer if I can fit 33's without digging out the hammer?
Thanx
Old 05-05-2012, 07:30 PM   #16
Dirty mall crawler
YotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shed
YotaKid62's Avatar
YotaKid62's Tacoma Gallery
Pop quiz!!! 33x12.50's on a 3.5 backspaced 15" rim running 3" lift. How much rub, if any, with pinch weld pounded?
Old 05-05-2012, 07:42 PM   #17
lonzorizo is a name known to alllonzorizo is a name known to alllonzorizo is a name known to alllonzorizo is a name known to alllonzorizo is a name known to alllonzorizo is a name known to all
lonzorizo's Avatar
lonzorizo's Tacoma Gallery
Lift don't matter. Tire has same travel as stock no matter what. If it rubs stock it will rub lifted when compressed. BFH and cutting some plastic and you can run 33's without rubbing (with the right backspacing).
Old 05-05-2012, 07:58 PM   #18
Dirty mall crawler
YotaKid62's Avatar
I have coilover spacers so there is less up travel than stock, hence, keeping the tires farther away from the fender, correct? Can you tell me if i'll rub frame with that backspacing?
Old 05-05-2012, 08:11 PM   #19
lonzorizo's Avatar
3.5"-4" you should be good. At least 4". At 4.5" my 285's(11.5) are close to the uca.
Old 05-06-2012, 02:15 PM   #20
capetaco12's Avatar
Thanx
You will need to pull out the hammer. its not that difficult and it takes 5 mins whack whack whack its flat Then maybe spray some bedliner on it if your worried about rust. Sadly there really are no definitive answers anyways. It depends on what you do with your truck. If you never left the road you might not even have to whack it.
I probably have just as much weight on the front and i have 881's so i have maybe an inch of lift and i run them just fine with some extra trimming.
3.5 sticks out a little farther than the 4" so you may actually rub a tad more on the PW. But if you beating it flat anyways might as go all the way.
What brand and style of tires are good and whats the biggest size i can run? fuentes89 2nd Gen. Tacomas 1 06-06-2011 08:47 AM
FS: OME 3.25" lift and BFG A/T Tires nastyblowpop Buy / Sell / Trade 18 08-16-2010 08:42 PM
Tires to fit OME 2" lift BlueTRD09 Wheels & Tires 4 08-02-2009 03:35 PM
2.5" leveling kit w/stock rims whats biggest tire i can run. abnranger80 Wheels & Tires 2 02-26-2009 09:24 PM
How big of tires can I run with a 3" body lift on a 2001 Tacoma? 01GREENTACO Wheels & Tires 8 10-21-2008 01:44 PM
