5100 Billys quick question.
Old 05-09-2012, 05:10 PM   #1
Hektor [OP] Hektor is offline
Hektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud ofHektor has much to be proud of
Hektor's Avatar
Hektor's Tacoma Gallery
Hi guys one question would the 5100 set at the middle setting get my truck level?? The rear is stock. I dnt want my truck to look higher on the front than the rear. Thanks
Old 05-09-2012, 05:22 PM   #2
radcat692000 is a jewel in the roughradcat692000 is a jewel in the roughradcat692000 is a jewel in the roughradcat692000 is a jewel in the rough
radcat692000's Avatar
radcat692000's Tacoma Gallery
with what kind of springs???
Old 05-09-2012, 05:32 PM   #3
Hektor's Avatar
Stock springs
Old 05-09-2012, 05:50 PM   #4
i would think it should get it damn close.
Old 05-09-2012, 06:12 PM   #5
Hektor's Avatar
Cool so it would be almost even
Old 05-09-2012, 06:14 PM   #6
kws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shedkws129 is one of the sharper tools in the shed
kws129's Avatar
kws129's Tacoma Gallery
I have the TSB rear springs and my billys with stock springs are set at 0.75 ( the middle setting) which gives the truck just a little rake so I think you should be right about level.
Old 05-09-2012, 06:16 PM   #8
Hunker Down You Hairy Dawg!
TacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shed
TacoDawgfan's Avatar
TacoDawgfan's Tacoma Gallery
By middle setting you mean 1.75? From what I've been told that at 1.75 you'll need the rear tsb or an aal and that it will sag bad in the rear with the least little load. I'm wanting to do mine.
Old 05-09-2012, 06:34 PM   #10
Originally Posted by Norton View Post
There is no "rear TSB" nor 1.75 setting for 1st Gens...
My bad, didn't even look at his sig. Didn't know about the 1.75 on the 1st gens though.
Old 05-09-2012, 06:34 PM   #11
Jnizzle is on a distinguished road
Jnizzle's Avatar
Jnizzle's Tacoma Gallery
curious what ppl say, im looking at the same for my taco
Old 05-09-2012, 06:42 PM   #12
Norton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shedNorton is one of the sharper tools in the shed
Norton's Avatar
Air Force: 90G0 & 17D4B w/ assignments in AFCC, AFSC, AFMC, AFSPC, AFRC, USAWC, NORAD-USNORTHCOM, USAFA, SAF
Norton's Tacoma Gallery
It's all good.
As was mentioned previously, the middle (1") setting will likely be the best one to level a 1st Gen with stock springs. Note that our only other options are no lift and 2.5", neither of which is likey to level the truck.
Old 05-09-2012, 09:44 PM   #13
Hektor's Avatar
It's all good.
Anyone else ???
Old 05-10-2012, 08:21 AM   #15
Taco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shedTaco76087 is one of the sharper tools in the shed
Taco76087's Avatar
Taco76087's Tacoma Gallery
It's all good.
X2
Quick question about 5100 install toyodajeff Technical Chat 1 03-13-2012 06:43 PM
Billys 5100/5125 Question Hektor 1st Gen. Tacomas 5 12-30-2011 04:07 PM
5100 quick question AlaskanTaco 2nd Gen. Tacomas 3 11-22-2011 10:33 AM
Quick 5100 question... Capazzi 2nd Gen. Tacomas 13 07-07-2011 10:03 PM
First Post!! Quick question about Bilstein 5100's... 05offroad Suspension 8 04-04-2011 12:32 PM
