The p0420 code few questions
Old 05-14-2012, 07:58 AM   #1
rll131 [OP] rll131 is offline
rll131
rll131 is on a distinguished road
rll131's Tacoma Gallery
I have a 2000 2.4 Tacoma code just came one. There are no exhaust leaks and the truck still runs great and I'm getting around 26-27 mpg so no loss in gas mileage. What should I start with what should I replace first I tried resetting and putting different gas popped back on about 70 miles later.
Also I looked at the o2 sensor it was pretty dirty old looking but there was no plug I've changedno2 sensors before but there was always a plug that you just unplug this one has no plug so how would I change it and which o2'sensor do I change for this cod ethe one before the cat and after the manifold or the one after the cat and before the muffler.
Old 05-14-2012, 11:11 AM   #2
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Either bad sensor or bad cat. Just have to narrow it down.
What do you mean by 'no plug'? Not connected to the harness?
I think you can test the sensors with a resistance check.
If either one fails that, then replace it.
Old 05-14-2012, 11:59 AM   #3
rll131
Yea there is no connecting harness on the o2 sensor behind the cat only on the one before the cat
Old 05-15-2012, 08:48 AM   #4
tan4x4's Avatar
Well, that has got to be the problem, then.
Is it possible that someone tried to steal your cat, and cut off
that wire, before giving up or being scared off?
If so, you need to re-establish the connection. There should be dangling
wires (one from the sensor, and one from the harness nearby).
P0420 code trmarshall1 1st Gen. Tacomas 3 04-13-2012 09:53 AM
P0420 Code flesheatingvirus 1st Gen. Tacomas 7 05-08-2011 10:27 PM
p0420 code wildjerseyfirefighter 1st Gen. Tacomas 2 11-27-2010 09:40 AM
p0420 code tacoma20021964 Performance and Tuning 6 01-28-2010 05:24 PM
Code P0420 CoreyF 1st Gen. Tacomas 1 01-26-2010 06:02 PM
