Leaf Springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by cr500taco, May 20, 2012.
  1. May 20, 2012 at 4:01 PM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    I am going to do a slight performance lift on my 97 Tacoma 4WD for the desert and trails. It has the stock coilovers and springs, right now, but I am going to get the Icon Coilovers and want to get Deaver springs for the rear. Deaver only has an add-a-leaf 1.5" lift available for my truck, but they have a full leaf replacement for the '98-'04 which is 1.5" lift, also. What's the difference between the '95.5-'97 and the '98-'04 springs and will the '98-'04 springs work on my truck with modification (I'm sure it will) and if so, is it worth the extra cost of the full leafs over the add-a-leafs and the effort of the modification to make the springs fit or should I just stick with the add-a-leafs? I think my OEM springs might need replacing, anyway.
  2. May 21, 2012 at 2:01 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Build your own leafs???
    I did mine for $60 including the donor leaf packs and new center pins!
    They came off a 2000 Dakota but you can use any off a fullsize truck. Just take your stock pack apart and ditch the overload and slap in the 2 new leafs or however many you want, i added 2 to mine and then my stock 3 leafs minus the overload so i now have a 5 pack and it rides a million times better!! Plus i got my 3" lift back out of it!
    Donors:
    And some flex shots with new leafs
    They flex really well and im more than happy especially for saving the $400 over an aftermarket pack!
