Rear spring question 99 tacoma
Old 06-08-2012, 11:48 AM   #1
Ibdoubled [OP] Ibdoubled is offline
Ibdoubled is on a distinguished road
Ibdoubled's Tacoma Gallery
I bought this thing a few months back and have been trying to get it back fairly stock it's a 4wd extended cab. Under the rear leaf springs is a fairly thick maybe 5/8" helper spring, I was wondering if this is stock because it rides like a tank. Or do they just comes with the leaf springs? Thanks
Old 06-08-2012, 11:50 AM   #2
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
That sounds like the overload, which is normal. There should be 3 leafs and one overload (thick one on the bottom)
Old 06-08-2012, 12:03 PM   #3
I think that's about how it looks it sure rides rough on my old bones
Old 06-08-2012, 03:02 PM   #4
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Its a pickup truck, not a minivan. Get used to it.
That overload leaf really does not affect the ride much, since it is curved downward. Its supposed to prevent damage to the main pack when the truck is overloaded.
More weight in the back (camper shell?) would help the ride a bit.
If the front suspension had been modified for lift, it could have worsened the ride if done cheaply.
Old 06-08-2012, 04:19 PM   #5
hossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud ofhossmaster has much to be proud of
hossmaster's Tacoma Gallery
What shock are you running in the back? If they are twin tube hyrdo shocks i can see why they beat the crap out of you. Maybe a set of bilsteins or other monotube gas shocks are in order
Old 06-09-2012, 05:20 AM   #6
Right now it has a bilstien on one side and a Monroe on the other, the idiot I bought if from must have broken the left rear shock mount, the sud portion, then in another act of brilliance he welded a bolt to hold the shock on. I need to fi a stud to reweld on before I can cut the shock off. I've looked on line for the mount but havent had any luck.
Old 06-09-2012, 07:55 AM   #7
The Rembrandt of Rattle Can
Madjik_Man's Avatar
Madjik_Man's Tacoma Gallery
Excuse me for riding the coattails of this thread but I have a question.
My rear leafs (original stock) have been frowning for years.
Will these things eventually just break in half? lol
Old 06-12-2012, 04:55 PM   #8
it's would probably be a better option to redo the shock mounts and move them away from stock.
search shock relocation and you will get some ideas.
Old 06-12-2012, 04:56 PM   #9
maybe, depends on abuse and road conditions. It has happened but more than likely one leaf breaks in the pack and you get a hell of a lean.
Just had Rear Spring TSB done, have question downey 2nd Gen. Tacomas 23 06-15-2012 06:55 AM
FJC rear spring question. capetaco12 FJ Cruisers 6 04-04-2012 11:07 PM
99 Prerunner Rear Shocks Question Anthony250 1st Gen. Tacomas 1 12-25-2010 04:15 PM
rear spring question HondaGM 2nd Gen. Tacomas 4 10-30-2009 04:02 AM
99 rear spring swap HELP Mr.Fahrenheit 1st Gen. Tacomas 2 04-12-2009 08:04 PM
