Spark Plug Replacement (and a laugh)
Discussion in '1st Gen. Tacomas (1995-2004)' started by zaoc, Jun 17, 2012.
  1. Jun 17, 2012 at 3:43 PM
    zaoc
    zaoc [OP] Well-Known Member
    Texas
    02 PreRunner
    fog light mod spray painted rims
    alright so when I was searching the forum for a how-to on changing plugs, I didn't find a whole lot of info. So, after finishing it myself I decided to do a lil write-up for other newbies like me.
    first things first, grab a brew
    2. check out and remove the hoses and such that are blocking the cylinders (don't have a pic of it clear, but you get the idea)IMG_20120615_114741-1_86e06f907e760ead1f9ffbf97fa849422b41c0a8.jpg
    3. remove the bolts and wires from the coil packs, then pull out the boot gently and set it to the side, on a clean surface. wipe off the cylinders carefully, making sure not to get any debris into the cylinder itself.IMG_20120615_132922-1_de99f1d2462cc67a9df097ac71c7b48b68b468a0.jpg
    4. ratchet out the plug until its completely unthreaded. and here's the tricky part. You could try your hardest to get the plug with just needle nose pliers, or you could make a ghetto parts grabber like me--
    that is a ordinary kitchen magnet wrapped up and held with my pliers, worked on the first try. just slide it in and around the plug and pull out (gently).
    5. all you have to do with the new plugs is apply the lube that comes with the plugs (autozone) and then drop them in and ratchet til they're tight, but don't over tighten and strip them.
    on to the driver side
    6. the driver side boots will simply pop out with enough force (once again, pull gently)IMG_20120617_164808_34cd7b99a4843ab9f72bc157e45fb7853d34cd9b.jpg
    once again you'll want to remove a couple items that are in the way, should be 10 mm bolts if your engine is like mine.
    7. lay those boots to the side, repeat the same steps with the plugs, slide in the new plugs, ratchet, replace the boots all around, and then replace all the hoses and things you had to move out of the way and you're done!:D
    (tools and stuffs)
    and here's another write-up http://www.4runners.org/writeups/sparkplugs/
  2. Jun 17, 2012 at 4:03 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    :thumbsup: Good work. I did this a few months ago but forgot to do step one. Will this cause any long-term issues, or should I re-do the job?
  3. Jun 17, 2012 at 4:12 PM
    zaoc
    Texas
    02 PreRunner
    definitely long term depression issues
  4. Jun 19, 2012 at 4:51 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    you know that they make spark plug sockets with little rubber boots that do this for you???
  5. Jun 19, 2012 at 6:13 PM
    Madjik_Man
    Colorado Front Range
    Don't get me wrong, I'm all for ingenuity, but isn't that what a spark plug socket is for?
    edit: I never read the whole thread before I reply. :mad:
  6. Jun 20, 2012 at 11:35 AM
    zaoc
    Texas
    02 PreRunner
    the spark plug socket i have doesn't. and instead of buying one i got smart
  7. Jun 20, 2012 at 12:58 PM
    scocar
    scocar hypotenoper
    Even with a sparkplug socket, you should wrap electrical tape around the top of the socket and the bottom of the extension (tape them together) so you don't lose lose it all in the hole.
    Blackwell99 likes this.
  8. Jun 20, 2012 at 1:29 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    8" long piece of fuel hose works great for fishing out and starting plugs. Grips the isolator perfectly, nice and bendy and you can't usually get enough torque on it to crossthread.
  9. Jun 20, 2012 at 1:37 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    They have locking extentions for this issue too. they will not release the socket unless you press the button.
  10. Jun 20, 2012 at 1:52 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Man you need to clean that engine bay. you should spray it down with a Degreaser like simple green or purple power, Let it sit for a minute and then hose it down. It will be som much more enjoyable to work on when it is clean in there. Also if you really want it to POP Throw some tire shine on the black parts and your engine bay will look better then the day it was new. Good Write up though and I like the idea with the magnet for those that might be a spark plug socket short of a full socket set LOL.
  11. Jun 20, 2012 at 1:58 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    nice! i need to do my plugs.
    also 1) miller light=:puke:
    2) i think we have the same beach towel. :eek:
  12. Jun 21, 2012 at 12:01 AM
    ffirg
    mike
    Anchorage, Alaska
    X2 on the electrical tape on the socket/ratchet. And no offense, but you should choose a better beer, haha. :puke: Try some Alaskan Brewing Company Summer Ale if you can get your hands on it.
    Oh...and I also have that "beach towel." I think it has been downgraded to a fish cleaning towel though.
  13. Jun 21, 2012 at 12:30 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Bosch plugs..... really?????
  14. Jun 21, 2012 at 12:43 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    LOL. I suspect many would just stop with step one.
  15. Jun 21, 2012 at 1:19 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I wouldn't buy into the myth that Bosch plugs don't work well with Tacomas, I went to parts store to get Denso (OEM) but they were out & had to go to Bosch, absolutely no issues at all, runs fine as it ever did...
    I did......:D
  16. Jun 21, 2012 at 4:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    The first step was to just grab "a brew", not that particular brew.
    Now if you'll excuse me...
  17. Jun 21, 2012 at 1:01 PM
    zaoc
    Texas
    02 PreRunner
    brew is brew sirs, personally i prefer a shot of tequila though. as for the engine bay its a work in progress. dad didnt do more than your standard maintenance, therefore im working on it
