how do i remove door panels from 1997 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ammobelt, Jun 19, 2012.
  1. Jun 19, 2012 at 9:30 AM
    ammobelt
    ammobelt [OP] Member
    1997 tacoma
    how do i remove the interior door panels from a 1997 tacoma reg cab without power windows?
  2. Jun 19, 2012 at 9:36 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    It should be two screws for the door handle/arm rest then you have to pry off the manual window crank. After that you should just be able to pry off the panel from the door. It's held on with many plastic clips between the panel and the door and they just pop out.
  3. Jun 19, 2012 at 9:42 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Jun 19, 2012 at 9:57 AM
    Squisha
    Squisha Well-Known Member
    Westminster, CO
    99 Taco Reg Cab 4x4
    This.
    The rag technique works. Use care when popping the panel off--at this age, the plastic clips can be brittle.
    It's also a good time to clean out the nasty crud that might have collected inside the armrest. I found old french fries inside mine when I went to clean it after I first bought mine last year. Pulling the armrest off is the only way to get it completely clean.
  5. Jun 19, 2012 at 5:22 PM
    ammobelt
    1997 tacoma
    ok..i'll try that..reason i want to take them off is i just got the truck[had an 88 toyota pickup that died]and there is a very annoying rattle coming from inside the passenger side and on the drivers side the lock sometimes won't open with the key and the door lock gets stuck down and even with a pair of vice grips won't pull up...jeez
  6. Jun 19, 2012 at 6:31 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    There is a 10MM bolt that keeps the window frame tight. It's on the very back of the door somewhere 3/4's of the way up.
    Try that before ripping the door apart.
  7. Jun 19, 2012 at 9:48 PM
    ammobelt
    1997 tacoma
    ok thanks..i'll try that first..my goodness..wasn't expecting this many responses this quickly..thanks guys and gals!
  8. Jun 19, 2012 at 10:15 PM
    Madjik_Man
    Colorado Front Range
    Welcome to TW :)
  9. Jun 21, 2012 at 1:56 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Good to know for when I find a donor tacoma to swap in power windows/doors plus door panel.
  10. Dec 1, 2023 at 12:00 AM
    breadandbits
    breadandbits Member
    99 3.4 5mt sr5 trd xtracab
    Adding reference here - you also need to remove the bolt for the interior door handle, which then slides forward to remove. If you have power windows and locks, the control panel needs to be removed to unplug - must be pried up in front, then slid forward (if you pry up the back you will break the clip). The triangular trim piece behind the mirror mount holds the separate top section of trim down, and must be pried out on top, then slid up (the bottom has a clip that will also break if pried). Then the bottom edge of the top trim strip must be pried away from the rest, to release and slide up and out. From there, it's just snap-in retainers. If you had some of the panel come off the retainers, it will look like you might have to slide the whole panel to get it off the retainers, but this won't work. The keyed shape of the holes for the retainers is just for installing the individual retainers in the panel before installation.
    Fantastic11 likes this.
  11. Dec 2, 2023 at 4:02 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Replying to an 11 year old thread. That might be a new record!
    Nothing wrong with it though. Info is always appreciated
    1997tacomav6 likes this.
  12. Dec 2, 2023 at 8:19 PM
    breadandbits
    breadandbits Member
    Hah, I figure there might be a new wave of folks picking these up as classic restoration projects. Otherwise at least I am likely to want to fuss with something and wish I had written these things down in a place that is easy to find.
