4 new superbright leds not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Texasdynaryder, Jun 24, 2012.
  1. Jun 24, 2012 at 8:01 AM
    Texasdynaryder
    Texasdynaryder [OP] Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    I just finished installing my Led behind the guages cluster and not a one works? Have I blown a fuse or not plugged something back in? Any ideas would be appreciated!
  2. Jun 24, 2012 at 8:04 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    are you sure they are put in correctly? with leds it matters which way they go in as leds have a postive and ground wire but have to be correctly oriented. standard halogens can run either way if i am not mistaken.
  3. Jun 24, 2012 at 8:04 AM
    Madjik_Man
    Colorado Front Range
    LEDs need to be plugged in a certain way due to polarity. Did you try flipping the bulb around to see if they work?
    I know it's a slim chance due to all four not working (what are the odds they all went in with the wrong polarity?) but it's worth checking out.
  4. Jun 24, 2012 at 8:05 AM
    Texasdynaryder
    Chance
    Paris, Tx
    Thanks I shall try right now!!
  5. Jun 24, 2012 at 8:09 AM
    Texasdynaryder
    Chance
    Paris, Tx
    That's a no go for launch Houston! Is there some kind of ground?
  6. Jun 24, 2012 at 8:11 AM
    2000GTacoma
    Snow Hill NC
    did you try swapping them around?
  7. Jun 24, 2012 at 8:12 AM
    trussell456
    trussell456 Well-Known Member
    Tyler
    Maine
    03 TRD V6 5-Speed
    Bilstein 5100's / Eibach's / AAL / All Pro Front Bumper / Skids / Billet Grill / 33x12.5x15 Duratracs / Dick Cepek DC-2's / TRS Retrofit / 20" Light Bar / 6" HID Fogs / Wet Okoles / WeatherGuard Tool Box
    Is your dimmer switch turned down? That would cause them to not work
  8. Jun 24, 2012 at 8:14 AM
    trussell456
    Tyler
    Maine
    03 TRD V6 5-Speed
    Also if you unplugged the dimmer switch to do the install and forgot to plug it back in they won't work either
  9. Jun 24, 2012 at 8:14 AM
    Texasdynaryder
    Chance
    Paris, Tx
    I even flipped just two around to try and see!
  10. Jun 24, 2012 at 8:17 AM
    Texasdynaryder
    Chance
    Paris, Tx
    Winner,winner, chicken dinner!!!!! Thanks chief!
  11. Jun 24, 2012 at 8:19 AM
    trussell456
    Tyler
    Maine
    03 TRD V6 5-Speed
    :cheers:No problem
  12. Jun 24, 2012 at 8:23 AM
    2000GTacoma
    Snow Hill NC
    good call knew that but had forgot about that
