1996 Rear Drive Shaft Vibrations
Old 06-29-2012, 03:43 PM   #1
lupy1234 [OP] lupy1234 is offline
lupy1234 is on a distinguished road
lupy1234's Tacoma Gallery
Hi...I have a 96 Tacoma 4x4 (2.7L) and the center bearing in the cardon joint failed. Toyota wants $1900 total to replace. Yep. Nough Said on that. Pulled the drive shaft off and running in 4WD until I find a replacement...only used to go and back to work. Does anyone know where I can find a replacement drive shaft? Or, I have heard that a 4Runner drive shaft (do not know the year) can replace it but it does not have the double cardon joint. Is this true? Any help will be greatly appreciated.
Old 06-29-2012, 03:48 PM   #2
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
driveshafts are not easy to come by ill pm you information about a guy i got mine from. and i do not know about a 4runner shaft would be nice to know though cause i know where one is.
Bad vibrations (need new drive shaft) ImthePrez 2nd Gen. Tacomas 7 05-17-2011 12:17 PM
rear drive shaft vibration BP348 Suspension 2 12-06-2010 05:03 AM
96 Rear Drive Shaft tomjodi 1st Gen. Tacomas 6 06-30-2010 07:00 PM
Which Prerunners have a two piece rear drive shaft? CaberMJ Technical Chat 6 04-25-2010 07:53 AM
rear drive shaft dodgeram293 2nd Gen. Tacomas 11 03-30-2009 03:23 AM
