1999 Taco 4x4 TRD lube oil transfer case question?
Old 07-01-2012, 10:17 AM   #1
sisu [OP] sisu is offline
sisu is on a distinguished road
sisu's Tacoma Gallery
I am at a loss for an answer. I've read, gone on line etc., but found nothing to help.
My shop manual says 1.2 quarts of lube oil for the fill, BUT the same book says fill until you can feel the oil below the fill plug. OK so I pumped in way over the 1.2 quarts and still don't feel the oil coming up to just below the fill lip as I did in the differentials and the transmission, in fact the differentials and the transmission met the guide lines put forth by the shop manual, but this transfer case has me buffaloed.
Anyone have a suggestion for the transfer case question/dilemma?
1999 Toyota Tacoma 4x4, TRD, manual transmission, manual (not electronic 4 wheel hi, and low), 3.4 liter engine
Here is a link that will suggest the same as I am stating about the 1.1 or 1.2 qts?
http://www.toyotapartsandservice.com...20Specs_V3.pdf
Old 07-01-2012, 12:33 PM   #2
My mistake on this question. I fingered it out!! Toyota has two plugs above the drain plug on the transfer case. I had missed the lower one, only about 6 inches or less above the drain plug, and picked the higher one near the top of the transfer case! I pulled the lower fill plug and let the excess drain out. My bad...
Old 07-01-2012, 04:36 PM   #3
Does anyone know why there are two filler plugs? The one I used is nearly at the top of the transfer case.
Question about differential and transfer case oil 4OYOTER 2nd Gen. Tacomas 4 06-09-2012 09:47 AM
Help with Transfer Case Maintenance 1999 SR5 thruhiker 1st Gen. Tacomas 5 04-13-2012 03:30 PM
Transfer case, transfer case actuator, and transmission question fireturk41 Technical Chat 0 05-01-2010 10:12 AM
i need tips on how to lube that u-joint in front of transfer case.. aficianado 2nd Gen. Tacomas 5 01-01-2010 10:57 AM
Question about Transfer case in 01 DC TRD Cheesycook 1st Gen. Tacomas 1 10-18-2009 01:40 PM
