Removed MAF, put back together, now there's a gap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jul 1, 2012.
  1. Jul 1, 2012 at 1:55 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    Took everything apart to clean the MAF, throttle body, change spark plugs and spark plug wires.
    Put everything back together, I mean there's only one way for it to go back together... and I noticed a tiny gap between the air box and the MAF sensor. 1/16th of an inch at most. Is this going to be a problem? Obviously the MAF sits inside the rear port of the air box far more than a 1/16th of an inch. Just wondering still if this may be a problem. See pics below.
    First pic is the gap.
    Second pic is me slightly pushing it together removing that gap. When I let go the gap appears again.
  2. Jul 1, 2012 at 1:57 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Mine has that. shouldnt be a problem
  3. Jul 1, 2012 at 2:01 PM
    Madjik_Man
    Thanks Boss
  4. Jul 1, 2012 at 2:03 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Total engine failure. Maybe throw a big ziptie around it while pressing in so it seals a lil better? Or a giant hose clamp.
  5. Jul 1, 2012 at 2:06 PM
    Madjik_Man
    Please don't fuck with me :(
    Was thinking zip tie(s). Once I brave going back out in the inferno, I'll throw one on.
  6. Jul 1, 2012 at 2:09 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
  7. Jul 1, 2012 at 2:10 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Does the air leak out of the gap?
  8. Jul 1, 2012 at 2:34 PM
    Madjik_Man
    Dunno.
    Guess I'll go put a wad of spit on it while it's running
    :notsure:
  9. Jul 1, 2012 at 2:37 PM
    VolcomTacoma
    Jeff
    NorCal
    Partial trolling...partial honest response...obviously that isn't going to cause an entire engine to sieze, but i would definitely throw something around that to try to get it to line up better with no gap.
  10. Jul 1, 2012 at 2:49 PM
    trmarshall1
    Tim
    San Jose, CA
    Agreed, just the catastrophic engine failure seemed a bit much:eek:
  11. Jul 1, 2012 at 3:30 PM
    Madjik_Man
    Piggy backing this thread... and speaking of engine failure:
    The spark plug boots on the driver's side seem very rudimentary in the way they sit on the valve cover. I mean all I did was put a little bead of dielectric grease on the underneath/bottom of the boot and push the spark plug boot as far as it would go down onto the plug. The flange of the boot is literally just sitting on top of the valve cover.
    Is this enough to make it water tight? Before I put everything back together I made sure I pushed everything into place as best I could.
  12. Jul 2, 2012 at 7:13 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I'de loosen every clamp on the intake hoses that I messed with, finesse the hoses and see if the gap does closes. My guess is the hoses are kinked.
  13. Jul 2, 2012 at 7:20 AM
    BamaToy1997
    Bill
    Navarre, FL
    Common situation on the Toyota style spark plug boot. What I do on all the Toyotas I work on is slightly pull the wire through the boot, as if I were disconnecting the wire out of the valve cover. This pushes the boot down closer to the spark plug, allowing you to get a better seal against the valve cover.
  14. Jul 2, 2012 at 9:21 AM
    Madjik_Man
    Thanks, I'll go try this.
  15. Jul 2, 2012 at 1:52 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    that is a good idea, I will remember that.... don't worry too much, the last two spark plugs on the driver side on my truck were just sitting in the hole.... not tighten at all.
  16. Jul 2, 2012 at 1:55 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    on the MAF mine did the same thing I think I loosened the 2 10mm bolt a bit and squeezed it together tight.. and then tightened.
