A/C isnt cold...
Discussion in '1st Gen. Tacomas (1995-2004)' started by yurokhip, Jul 10, 2012.
  1. Jul 10, 2012 at 5:06 PM
    yurokhip
    yurokhip [OP] Active Member
    yreka c.a.
    01 limited trd off rd four door
    tinted windows, 2 in lift, sittin on 31's dick cepek rims
    my a/c isnt cold nemore in my truck the ac pump i think it is? is making noise on front of my motor have no clue? ne ideas? ne1 knw watsup? gotta new baby n neeed a/c
  2. Jul 10, 2012 at 6:17 PM
    ntoyotap
    ntoyotap Member
    Nick
    Massachusetts
    '96 Lexus sc400 (DD)
    Stock... Would love a lift (and tires to match), a snorkel, sliders, and a winch
    Could be a lot of things. What kind of noise is it making (squeal, howl/groan,..)?
  3. Jul 10, 2012 at 10:20 PM
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    someone else had that pulley come apart. so the belt wasnt spinning the pulley.
  4. Jul 10, 2012 at 11:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The pump you refer to is the A/C compressor & the noise you speak of , is it all the time ? or does it happen when you turn/push the ac switch on ??
    If its constant after starting up without energizing the ac switch, good chance the clutch on compressor is gone out, if it only makes the noise when you turn it on chances are the clutch & compressor are good & your refrigerant has leaked out...if this is the case you could drop some dye into the mix when re charging the system, if theres a leak the dye will blow out wherever the line breach is leaving a mark/stain where the leak is..
  5. Jul 10, 2012 at 11:23 PM
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    If nothings really broken, try this:
  6. Jul 12, 2012 at 6:31 PM
    yurokhip
    yreka c.a.
    yea it only makes a noise when i turn on the ac it does sound dry, n yea its kinda a squeel.. i took off the ac fan thing under the glovebox n cleaned the shit outta that.....
    where do i put the ac pro in? rite by the pully wheel? at the bottom right side of the engine?
  7. Jul 12, 2012 at 6:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    There's a service valve (schrader valve) in the refrigerant line for that. Good move cleaning the coil under dash, most A/C failures are due to dirty coils.... As far as the noise goes when energized tells me that at least the compressor is kicking in, its not too difficult but get a manual showing proceedure, & check A/C belt also if its squeeling, if its good then the compressor may be getting ready to shit itself...
  8. Jul 12, 2012 at 6:45 PM
    yurokhip
    yreka c.a.
    rite on man helped hella i had no f'in clue.. u ever need projector lights i gota buddy that does em looks badass fairly cheep for em to he sayss..
  9. Jul 12, 2012 at 7:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Wrong answer.
    That is the best way to completely fuck the system up and end up spending $1000 or more to fix it properly, when it may only be a $200 problem today.
  10. Jul 12, 2012 at 7:09 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And if the compressor is kicking on, then there is sufficient charge to operate the system.
    The DIY refill kit is not the solution. It needs to be looked at by someone who knows what they are doing.
  11. Jul 12, 2012 at 7:19 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    will agree with above poster!!!! you can save lots of money on do it yourself stuff, but this is one of the things that takes proper tools and training or you will blow out the whole system.
    (and I have seen back-yard experts do it)
  12. Jul 13, 2012 at 8:27 PM
    yurokhip
    yreka c.a.
    aite thanks ill jus take it in ha..
  13. Jul 13, 2012 at 8:34 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    yap thats why i have my own robinair recovery machine [​IMG]
  14. Jul 13, 2012 at 8:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It could be low and causing it to cycle, but he didn't indicate that it was cycling.
    He said it was operating and making noise.
    And cycling is normal for modern AC systems, so we can no longer determine a low charge state by simply listening for cycling.
  15. Jul 13, 2012 at 8:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Meh, just purge it into the atmosphere.....:eek::p j/k
  16. Jul 13, 2012 at 8:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I could have been more clear, but my main point was that someone who knows what they're doing needs to look at it.
    We can't troubleshoot a "noise" from here.
    It might be normal noise from the compressor, or he might have one that's ready to seize and throw the serp belt.
  17. Jul 13, 2012 at 8:54 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    oh hell ac pro commercial just came on lol.
    i dont care bout killing ozone. i just want to read the pressures, see how much comes out. what vacc it holds. how much oil was recovered. and go from there. add to much will diffidently mess these new systems up.and blow seals.
  18. Jul 13, 2012 at 8:54 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well remember tho' , low refrigerant isn't going to allow any cycling because a call for cool has been made & because of the low/non existant refrigerant theres not enough (or any) to super heat/ super cool/expansion (gas) sub cool (liquidfy) the compressor will just keep pumping away trying to hit the demand for cool..but it can't because of the low/non refrigerant
  19. Jul 13, 2012 at 9:01 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    pst do not question the "RICH" :spy: :D
  20. Jul 13, 2012 at 9:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Unless the newer systems are lacking the pressure sensors that the older systems had....
    Static pressure sufficient to kick the compressor on, it starts, low side drops below lower limit, compressor releases until the system bleeds back to equilibrium and the low-limit switch again kicks the compressor on... endless cycling with little to no cooling.
    Admitted... the newest system I've worked on was from the mid 90s.
