Regearing to a 4:56 or 4:88??!! Help
Old 09-24-2012, 11:54 AM   #1
Critta93 [OP] Critta93 is offline
Critta93 is on a distinguished road
Critta93's Avatar
Critta93's Tacoma Gallery
So I bought another Tacoma the other day (3rd so far) and its a 2000 3.4l v6 5 speed and has 6" lift and 35x12.50s on it. It has pretty good power surprisingly, I think part of it is the low miles (65000). I am interested in regearing to a 4:56 or 4:88 but I don't want to lose mpg but do want more power. Any opinions?? I'm not very familiar with gearing.
Old 09-24-2012, 12:04 PM   #3
mmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shedmmcmahan2206 is one of the sharper tools in the shed
mmcmahan2206's Avatar
Firefighter: Firefighter/EMT(Medic in trailing)
mmcmahan2206's Tacoma Gallery
Go 4:88s, bud! I have the same truck (00 Taco 3.4L w/ 6" suspention and 3" body running 35x12.50R15 BFGs) and it runs like a champ now! The 4:56s wouldn't be enough for the 35's especially if you do anything off the paved road! Going with the 4:88s was def my best and favorite mod since it brought back the V6 power! Hope this helps!
Old 09-24-2012, 12:05 PM   #4
Wait for it...
StAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shed
StAndrew's Avatar
Navy: SWO
StAndrew's Tacoma Gallery
[Im assuming you have 16" rims] I went here first to calculate the metric size:
http://www.xtremeterrain.com/tire-si...on-metric.aspx (came out to 318/76 r16)
I then pluged that into here:
tire calculator
At the bottom it tells you what ratios give the best MPG's (yellow), stock ratio (green), and more power (red).
Looks like either would be good for MPG's, I'd recomend the 4.88's or 5.29's for a bit more power but thats just me .
Old 09-24-2012, 12:14 PM   #5
shelshelly90 is on a distinguished road
shelshelly90's Tacoma Gallery
i would go with 4.88, i have an 03 with 33X1250X15 and i got 4.88s and the were to low, went to 4.56s after the 4.88 diff blew up. 4.88s would be perfect for 35s
Old 09-24-2012, 12:56 PM   #6
Critta93's Avatar
Alright guys thanks!!! That's exactly what I needed. Now, how expensive are they and can I put them in myself? If not, what's the total price of getting them and having them installed?
Old 09-24-2012, 07:05 PM   #7
Solid Axle FTMFW!!
Supra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shed
Supra TT's Avatar
Supra TT's Tacoma Gallery
Gears are not for the average DIY. If they are not set-up properly you will destroy them. It's best left with a professional. I reccomend uninstalling them to the part where they are actually just a unit and bring them in. It will save you hundreds. Otherwise you are probably looking at over $600 for install, or over $1k as I've read from people.
Old 09-24-2012, 07:07 PM   #8
dfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the sheddfrugia is one of the sharper tools in the shed
dfrugia's Avatar
dfrugia's Tacoma Gallery
4.88 with a Detroit Locker.
Old 09-24-2012, 07:08 PM   #9
east coast gear supply is the best that i have found, after the core is returned..
Old 09-24-2012, 08:38 PM   #10
RTO
FailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shedFailRated is one of the sharper tools in the shed
FailRated's Avatar
FailRated's Tacoma Gallery
Go 4.88's. I have 4.56's and run 265/75's and 33x10.50's and almost wish I would have done 4.88's. Also, if you have some mechanical ability, remove the front diff and rear third member yourself and then take them to a shop to get the gears installed. You will save some coin doing it this way and also gain the experience of removing your differentials which could prove to be valuable down the road.
Old 09-25-2012, 04:28 AM   #11
alove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shedalove0750 is one of the sharper tools in the shed
alove0750's Tacoma Gallery
Go ahead and do the 4.88's, I regret doing 4.56's. They were almost perfect when I had my 33x12.50 Duratracs, but that tire is small to begin with (32.5 or .6) Now that I'm running the MTR's (heavier/taller) I can feel them pretty bad. I am going to end up going to 4.88's before it's all said and done.
Old 09-25-2012, 05:42 AM   #12
worthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shed
worthywads's Avatar
worthywads's Tacoma Gallery
If you want to see how 4.88s would effect your highway mpg just drive in 4th and see if your mpg tanks.
But are you sure what your gears are now?
Old 09-25-2012, 06:24 AM   #13
His gears are prolly the 4:10s since he's still able to get some power and roll down the road! But the re-gear will actually help with mpg's when doing city driving just due to the fact that he wont be having to romp on the gas and stay on the gas just to get started down the road!
I got my gears (ring and pinion) and both (front and rear) master install kits from Randy's Ring and Pinion using all Yukon parts! Hope this helps:
Order Summary:
Product Number Price Qty Total
YG TV6-488 $221.53 1 $221.53
YG T7.5R-488R $228.39 1 $228.39
YK T7.5-V6-FULL $215.73 1 $215.73
YK TACOMA-LOC $293.80 1 $293.80
YY T35040 $51.89 1 $51.89
Subtotal: $1,011.34
Sales Tax: $0.00
Shipping: $0.00
TOTAL: $1,011.34
Old 09-25-2012, 07:56 AM   #14
Critta93's Avatar
Alright thanks.. I'm definitely going with the 4:88. I have the 4:10 now and want my power back since I'm running 35s. Thanks for the info. I found a guy to install whatever I get for about 200. Not bad. So where is the best place to buy?
4.56 vs 4.88 Gears Manwithoutaplan 2nd Gen. Tacomas 71 09-28-2013 04:56 AM
4.56 or 4.88 ? toyotadan98 1st Gen. Tacomas 19 02-15-2012 11:14 PM
Need opinions: 4.56's or 4.88's Ozziwald 2nd Gen. Tacomas 32 10-24-2011 07:56 PM
Regearing to 4.56 07tacoswb 2nd Gen. Tacomas 30 03-15-2011 12:08 PM
Regearing to 4.56's mpleitez Performance and Tuning 25 05-26-2009 05:37 PM
