2001 missing when wet
Discussion in '1st Gen. Tacomas (1995-2004)' started by luckydogie, Oct 18, 2012.
  1. Oct 18, 2012 at 9:42 AM
    luckydogie
    luckydogie [OP] Member
    01 prerunner
    I have a 01 prerunner with a 3.4 that misses after a rain, just sitting in driveway.I have code po300 and misfires on cy4 and 6. If i spray coils down with water it will happen, If i spray plug wires down it wont. What is the chance i have 2 bad coils? Trucks has 178,000 miles and runs great other than this new issue. The miss goes away after a couple miles. Thanks for any help.
  2. Oct 18, 2012 at 10:17 AM
    Grousehunter 12
    Grousehunter 12 Well-Known Member
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    Tundra brakes on front
    If those are the factory coil boots then there is a good chance that is your problem . My guess is you coils are good , your coil boots not so much . At 178K I would replace all the coils , which would also replace the boots . If you replace the boots alone they can be had for about $30 from Amazon.com, Denso 671-6248 is the factory boots,they can't be bought from a dealership as they only sell the complete coils. The O.E. coils are Denso 673-1201.
  3. Oct 18, 2012 at 10:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can swap one of the coils with the number 5 coil (left the boots where they are) and repeat your rinse test and see if the code changes to 302. Then you'd knoe for sure if it was a coil.
  4. Oct 18, 2012 at 11:15 AM
    luckydogie
    01 prerunner
    If it is a coil boot how come the misfire is on the other bank?
  5. Oct 18, 2012 at 12:04 PM
    luckydogie
    01 prerunner
    Swapped 5 coil with 3 and spayed them light didnt come on but my scanner has po 300 code. It didnt miss long enough to post a clylinder. Never have a problem running down the road only after sitting with rain.
  6. Oct 18, 2012 at 12:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    This is the coil boot, which are on the bank you are having issues with
  7. Oct 18, 2012 at 12:20 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    I had this code recently when it rained. (don't know why since nothing is wet underneath the hood) but I used dielectric grease in the boots and it seemed to have solved the issue.
