Rim Fitment
Discussion in '1st Gen. Tacomas (1995-2004)' started by jhaynes, Nov 5, 2012.
  1. Nov 5, 2012 at 6:42 AM
    jhaynes
    jhaynes [OP] Member
    Jerry
    Vicksburg, MS
    1997 4x4 Regular Cab
    Will a 16" alloy rims from a 2005 prerunner fit my 1997 tacoma which has a 15" rim size?
  2. Nov 5, 2012 at 12:35 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
  3. Nov 5, 2012 at 1:13 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    thought the '05 had a 5.25" BS'ing
    and the 1st gen had 4.50" BS'ing
    wouldn't that difference possibly cause some frame/UCA rub
    at full steering lock on the 1st gen ? :notsure:
    less of concern with a smaller, narrower tire ? :notsure:
  4. Nov 5, 2012 at 1:15 PM
    sirsaechao
    Tim
    CA
    You can run it just can't go wider then stock size tires.
  5. Nov 5, 2012 at 3:51 PM
    jhaynes
    jhaynes [OP] Member
    Jerry
    Vicksburg, MS
    Thanks for the quick reply, since my truck is a 4x4 would you leave the center caps off on the front to allow from the hubs?
