Replacement Washer Fluid Reservoir Neck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TinkerToy, Dec 31, 2012.
  1. Dec 31, 2012 at 4:44 PM
    TinkerToy
    TinkerToy [OP] I Can't ReMember
    Phergus
    The Sooner State
    11' PreRunner SR5 TRD Quad Cab
    Contemplating racing stripes, a NOS sticker, & some glasspacks. I hear they make you go faster...
    The neck on my washer fluid reservoir is leaking, but the lower portion is intact...
    Does anyone know if the filler neck itself can be replaced or will I have to replace the entire assembly?
    Also, can anyone recommend a vendor OTHER than the dealership?
    I'm trying to avoid some "Southern Engineering" but I'm not opposed to it! :mudding:
  2. Dec 31, 2012 at 4:47 PM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    Same here, my cracked and was leaking and I bandaged it up with duct tape. Would like a more permanent solution as well.
  3. Dec 31, 2012 at 4:50 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Fiberglass the neck.. I should have done that with mine.
    I replaced mine last year... kicked my self for doing it.
  4. Dec 31, 2012 at 4:53 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
  5. Dec 31, 2012 at 5:17 PM
    smuook
    Smuook
    Loganville, GA
    $75 is too much for something that is probably going to crack again. May do the fiberglass or perhaps another solution.
    TwoStickTrick likes this.
  6. Dec 31, 2012 at 5:27 PM
    KenLyns
    Belly of the Beast
  7. Dec 31, 2012 at 5:30 PM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Plastic weld and then epoxy and then wrap with something?
  8. Feb 10, 2013 at 10:44 AM
    smuook
    Smuook
    Loganville, GA
    Finally got around to fixing this. Used the fiberglass repair method. Pretty easy to do, but fiberglass is messy. Use gloves! Access through wheel well, remove 4x10mm bolts, unplug connector, unplug washer hose. Reservoir will drop down. Make sure you clean the neck good and remove dirt. I used 5x2inch fiberglass strips. Working from top down (so overlap doesn't create upward facing pocket) I just layered the strips all the way to the bottom. Waited until cured, then reinstalled. I'm leaving the deckplate on (from deckplate mod of air filter box) so I don't pop a maf code. Will removed deckplate again in a few days. Overall pretty easy to do. It's not a work of art, but it should last the life of the truck.
    Access through wheel well and remove 4 bolts:
    Unplug connecter and hose:
    Broken neck due to cracking. These seems to be a common problem and I could see more cracks forming:
    Fiberglass repair kit:
    Beer time:
  9. Feb 10, 2013 at 10:51 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Nice write-up. Thanks. Mine is cracked also, so it is probably just a matter of time before it starts to fall apart.
  10. Feb 10, 2013 at 11:38 AM
    smuook
    Smuook
    Loganville, GA
    NP. Really not hard and took less than 1 hour.
  11. Feb 17, 2013 at 8:53 PM
    TinkerToy
    Phergus
    The Sooner State
    I dig it! I'll tackle it when the weather stays warmer longer than a day or two. We had snow yesterday & it was 70 today...ugh!
  12. Feb 17, 2013 at 9:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I think $75 for 15 years is not such a bad deal.
    Rocan likes this.
  13. Feb 17, 2013 at 10:12 PM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    If it's only age cracked, find a TAP plastics near you an buy a quart of gelcoat :D
    I did that for my sisters Camry that was old and weathered and hasn't leaked a drop since.
  14. Feb 18, 2013 at 3:12 AM
    smuook
    Smuook
    Loganville, GA
    Where did 15 years come from? Mine started cracking at 4 years.
  15. Feb 18, 2013 at 11:40 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    OP's truck is a '98
  16. Feb 18, 2013 at 12:16 PM
    smuook
    Smuook
    Loganville, GA
    They don't last that long. It's probably been that way for years. I was living with mine for years with duct tape around it. It's not a vital component though, so many people, as did I, just live with it. Which brings me back to my original point... I wouldn't pay $75... or even $10... for something that is proven to fail. I had extra fiberglass from my Satoshi and it is rock solid know for as long as I own the truck.
  17. Feb 18, 2013 at 5:32 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I have the same issue. Cracked neck. Instead of fixing or replacing that one, I've been thinking about relocating the whole thing to the empty space where ABS would be. Looks like a lot of guys who run aftermarket bumpers are doing this, so I might hop on that route.
  18. Feb 18, 2013 at 7:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not a bad idea.
    You can use an OTC radiator overflow retrofit tank and OTC standalone pump.
  19. Feb 18, 2013 at 7:59 PM
    SpeedoJosh
    Florida
    Yea. There's a handful of write-ups in the sticky in this section. Some people even used a nalgean bottle. Looks like they just drilled a hole, and reused the old pump, and just rerouted the wires/tubes.
  20. Feb 18, 2013 at 8:07 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    A reservoir from a 4runner will bolt directly in. And those have removable necks. The necks on them must be made from something different because they don't crack like tacomas. It does have 2 pumps though. So either modify it or you can try carefully removing the neck from the tacoma reservoir and then figure out a way to have the 4runner neck in it.
