Passenger side window wont move!
Old 01-11-2013, 05:53 PM   #1
01kingtaco [OP] 01kingtaco is offline
01kingtaco is a splendid one to behold01kingtaco is a splendid one to behold01kingtaco is a splendid one to behold01kingtaco is a splendid one to behold01kingtaco is a splendid one to behold01kingtaco is a splendid one to behold01kingtaco is a splendid one to behold
01kingtaco's Avatar
01kingtaco's Tacoma Gallery
today i went to roll up my passenger window in my truck and it wont move at all, the motor dosent make any noise and it dosent work from both the driver side or passenger side switch
Could my window motor took a crap? im not to good with electrical but can figure some stuff out
also to take the door panel off is the one screw in the door latch and the 2 screws in the the door handle all it needs to pop of?
any help would be awsome since it rains ever day in hawaii.
Old 01-11-2013, 05:56 PM   #2
Ghost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shedGhost848 is one of the sharper tools in the shed
Ghost848's Avatar
Ghost848's Tacoma Gallery
Life is ruff in hawaii lol... Im guessing a connection came loose at the motor. They normally slowly go then die... Cant answer you door panel question though.
Old 01-11-2013, 05:58 PM   #3
nucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shednucktaco is one of the sharper tools in the shed
nucktaco's Avatar
nucktaco's Tacoma Gallery
from the sounds of it i would guess the motor is fvcked. seems unlikely that both the switch on your drivers and passenger side are dead. maybe check your fuses aswell? id also hook up a jumper pack to the wires coming out of the window motor and see if the motor attempts to move up or down. tried this method with my pathfinder and ended up being a switch.
Old 01-11-2013, 05:58 PM   #4
I sell fishing and fishing accessories
wildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shedwildjerseyfirefighter is one of the sharper tools in the shed
wildjerseyfirefighter's Avatar
Firefighter:
wildjerseyfirefighter's Tacoma Gallery
Send a message via AIM to wildjerseyfirefighter
Is the window lock off?
Old 01-11-2013, 06:12 PM   #5
This is my derpawayinator!!!!!
NelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shed
NelsonTacoma's Avatar
NelsonTacoma's Tacoma Gallery
You wouldn't believe how many times that is the reason.
Also OP, if you open the door and hold the switch to roll the window down and slam the door shut real hard it might jar the motor and make it work temporarily. I've diagnosed many window motors at work this way. Disclaimer: I you break the door or any related components I take no responsibility for it. I've never had it happen to me, but there's always a first time.
Old 01-11-2013, 06:13 PM   #6
Firefighter:
Ive had it happen to me before. Lol
Old 01-11-2013, 06:16 PM   #7
Me too. I replaced a window regulator on a customers car at work and thought I misdiagnosed it, spent 20 minutes trying to figure it out and one of the other techs said "did you check the lock switch?"
Old 01-11-2013, 07:52 PM   #8
The Rembrandt of Rattle Can
Madjik_Man's Avatar
Madjik_Man's Tacoma Gallery
Check to make sure nothing came loose in the module (behind driver's side kick panel).
In order to take the door panel off:
Remove screw in door handle.
Remove two screws in door pull.
Slide the door handle towards the front and slightly pull it out.
To remove the pull rod off the door handle, remove that clip by pulling the portion on the horizontal portion of the rod towards you. Then simply lift the vertical portion of the rod out of the rest of the clip. The clip should remain on the door handle. (see below pic 1)
Pop off the trim that surrounds the window and door lock switch. Unclip the wiring harnesses off each switch (see below pic 2)
Then there are maybe five or six clips on the edge of the panel. Get a panel/trim removal tool or carefully use a screw driver.
Once all the clips are popped, simply lift up and off the door.
Here's a pic of how not to remove that clip from the pull rod. Notice how half of the vertical piece of the clip is broken. That's because I tried removing it from the handle. The fatter part of the clip that is attached to the horizontal part of the rod simply "unclips" by pulling it towards you. It's simple once you see it.
And here's a picture of what it looks like under the panel so you can see where the clips go:
Old 01-11-2013, 09:12 PM   #9
Daily Driver "Plus"
smuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud ofsmuook has much to be proud of
smuook's Avatar
Navy: 24 years Active Duty
smuook's Tacoma Gallery
Something similar actually happened to me. Take a look at your switches. I had a failed switch on the drivers side controls... and it did prevent passenger side from working. Check for freedom of motion of switch and that it returns to correct positions. Pop out switch controls and look for physical damage or burn marks from arcing. I ended up buying driver switch assembly on ebay and fixed problem.
Old 01-12-2013, 11:38 AM   #10
01kingtaco's Avatar
Thanks for all the help guys gana try and figure it out today il let u know
Passenger Window Wont Go Up or Down? 98Tacomav6 1st Gen. Tacomas 0 09-12-2011 06:44 AM
passenger side door lock wont turn boybands are lame 1st Gen. Tacomas 8 04-11-2011 09:48 PM
Passenger window wont roll up rraether 2nd Gen. Tacomas 9 10-18-2010 12:53 PM
I need help diagnosing my passenger side window... OCTaco 2nd Gen. Tacomas 7 05-04-2010 03:41 PM
Power window- passenger side JONNY TACO 2nd Gen. Tacomas 4 09-08-2009 08:25 AM
