New clutch Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaBoy1998, Feb 23, 2013.
  1. Feb 23, 2013 at 1:42 PM
    YotaBoy1998
    YotaBoy1998 [OP] New Member
    Replaced my clutch and flywheel last week. Pretty uneventful until the test drive. There was a rubbing sound and shaking coming from the transmission when releasing the clutch under load in any gear and also when I go over bumps while in gear. When it is in gear and clutch is fully released it doesn't do it, except for the bumps in the road.
    Took the transmission back out today and the new pilot bearing came out with it. Not sure if that could be the problem or not. Kind of odd for that to just come out IMO. Regardless, put the tranny back in after reseating the pilot bearing and........ wait for it.......... same problem.
    I have searched the forums and cant find anything that resembles it. I am stumped. Not to mention, tired of removing that tranny. BTW, it is a 1998 4x4 3.4L.
    Input shaft bearing? Pilot Bearing? Throw out bearing? Bad clutch?
  2. Feb 23, 2013 at 2:06 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    HMMMM--Motor mounts?
    The Pilot bearing should have been tight!
    Just trying to rememeber what happened when I did my 91.
    Hope someone that does trannys can help.
    What a pain in the ass job-decided I would not ever do that again.
  3. Feb 26, 2013 at 9:50 PM
    skid89
    skid89 New Member
    Vancouver
    96 Tacoma 4x4 3.4 5spd
    Old Man Emu Lift Kit 2004 Front End
    I have a 1996 Tacoma 3.4, with the exact same problem. Put in the new clutch and now I have this annoying "grabbing" or "jumping" when releasing the clutch
  4. Feb 26, 2013 at 10:34 PM
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    Is there any possibility of misalignment between the transmission and the engine?
  5. Feb 26, 2013 at 10:57 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Kinda the same thing here. I don't know if its the new clutch or the new everything, but at low RPM's under load it feels like its "choking" and the rear end kinda jumps around. Slipping clutch?
  6. Feb 27, 2013 at 5:59 AM
    C O R E
    C O R E Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
