1995 super charger questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by toastyjosh, Apr 8, 2013.
  1. Apr 8, 2013 at 8:37 PM
    toastyjosh
    toastyjosh [OP] Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    So I have a line on a charger for 6 bills. I was reading on the TRD install PFD that they do not recommend putting them on 95and 96s due to the ecms not really able to deal with it. The say 97s and on basicly.
    What do you guys think, any one have one on a 95 or 96?
  2. Apr 8, 2013 at 9:08 PM
    Q Source
    Q Source Well-Known Member
    California
    04 PreRunner
    Supercharged, TRD Headers, URD 7th/SHORTIE 800cc injector, Snow Performance Water/Meth Kit, Deaver FJ59, Icon UCA, Fox Extended Travel Remote Resi, TG Front and Rear Bumpers, Deckplate Mod
    From what I have read you need to Swap your ecu from a 97 or later taco, not sure why, but I'm sure some more informed folk will chime in.
  3. Apr 9, 2013 at 10:36 AM
    toastyjosh
    northern New mexico
    Yea the TRD stuff said that this was not so good.
    http://reviews.mtbr.com/video-al-pesto-riding-in-san-romolo-with-floriane-pugin
    There has been some confusion as to which
    vehicles the supercharger works best on.
    Please clarify.​
    While the supercharger will fit the engine, the Electronic Control
    Units (ECUs) used in 1995 and 1996 T-100 and Tacoma trucks
    do not respond as well to supercharging as do the 1997 and
    later vehicles. For this reason, TRD does NOT recommend the​
    supercharger for the 1995 and 1996 Tacoma and T-100 trucks.
    Do I have to change the vehicle’s computer
    (ECU)? Do you suppose it’s possible to change
    out the 1995 or 1996 computer (ECU) with the
    ‘97 or ‘98 model?​
    TRD does NOT recommend using any computer for your vehicle
    other than the one that is made for the specific vehicle by Toyota.
    TRD offers no modified or alternative computers, as the TRD
    supercharger has been designed to be compatible with the factory
    computer.​
    Figure A​
  4. Apr 9, 2013 at 10:40 AM
    toastyjosh
    northern New mexico
    Why doesn't TRD recommend the supercharger for 95-96 models?
    - The reason they are not recommending the supercharger for 95-96 years is because the truck's commputer (ECM) can not deal with the fact that there is not enough fuel. What happens is the ECM tries to fix the problem by retarding the timing. (It does this so much that you want gets as much of a HP gain.) Another reason is the ECM has two operating modes, open & closed loop. The ECM stays in "closed loop" when the truck is under about 80% throttle. It does this by changing the air/fuel mixture from rich-lean-rich-lean, to save gas. Once the throttle is opened more than about 80% it goes into open loop where the air/fuel mixture stays at its maximum efficiency. Since there is not enough fuel under full throttle; the 95-96 years will not go into open loop with the supercharger which robs the HP. To correct this problem see, Fuel Modifications below.
  5. Apr 9, 2013 at 12:42 PM
    DAMOS
    DAMOS Well-Known Member
    Eugene, Oregon
    04 Dub Cab TRD 4x4
    TRD sc Magna flow cat back
    change the oil before you install it
  6. Apr 9, 2013 at 6:03 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    I have it on my 95 at its got 220 on it and still runs decent starting to loose compression at the rings tho
  7. Apr 10, 2013 at 5:20 PM
    toastyjosh
    northern New mexico
    yea I have 267,xxx on mine I am starting to think that the charger is a bad Idea.
  8. Apr 10, 2013 at 5:52 PM
    Hambone155
    omaha
    Why is that?
  9. Apr 11, 2013 at 9:26 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    okay but you should hook us up with that charger :D
  10. Apr 11, 2013 at 5:30 PM
    toastyjosh
    northern New mexico
    too many miles on the motor. I mean the thing runs good. What do you guys think?
  11. Apr 11, 2013 at 7:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just get a 97 ecu.
    95-96 ecus retard the timing some it doesn't run right.
    Just buy an exact 97 ecu and you'll be fine.
  12. Apr 11, 2013 at 7:56 PM
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    do superchargers put alot more stress on the motor? specially if it has more miles? is it a bad thing to put on?
  13. Apr 11, 2013 at 8:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Of course it stresses it more haha
    But not a bad thing if your keep good care if your motor. I have a buddy that put one on at 186k. Has over 200 now amd still kicking.
    Just keep good care of it
