1995 outside door handle
Old 04-10-2013, 02:11 PM   #1
mkhenson [OP] mkhenson is offline
mkhenson is on a distinguished road
mkhenson's Tacoma Gallery
I have had the outside chrome door handle replaced twice on my 95 taco. Seems like i am having to lift the handle so far, that the handle is actually cracking. There must be an adjustment somewhere. Is this something that someone could walk me thru? I'm not even sure about how to remove the door panel. (assuming that needs to be done) Thanks for any help you can give.....MH
Old 04-10-2013, 05:00 PM   #2
The Rembrandt of Rattle Can
Madjik_Man's Avatar
Madjik_Man's Tacoma Gallery
Seems like you got some issue with the linkage inside the door.
Removing the door panel is easy.
Off the top of my head, remove the two screws in the arm rest/pull. Pop off the trim panel around the switches (if you have any), then remove the wire clips. Remove the little screw in from the interior door handle. Remove door handle from rod.
Then there's like 6 or so clips behind the panel that you just slowly/carefully pry. Lift up and off to remove the panel.
Old 04-11-2013, 02:08 AM   #4
brettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shedbrettb is one of the sharper tools in the shed
brettb's Avatar
brettb's Tacoma Gallery
Im having this problem as well!
Old 04-11-2013, 02:09 AM   #5
brettb's Avatar
Originally Posted by Blackdawg View Post
Actually you need to re align the actual door. When. Rebuilt my truck I noticed I was doing that to the point my handle was about to crack. Turns out I was having to literally lift the door up out of the latch.
Readjusted and is fine.
How Did you readjust the door?
help door handle wont open door 00taco 1st Gen. Tacomas 9 01-09-2015 02:40 PM
How do I remove door handle from front door panel w/o breaking plastic sleeve on rod? Madjik_Man 1st Gen. Tacomas 30 11-03-2012 10:36 PM
DRIVERS DOOR STICKING & OUTER DOOR HANDLE TACO671 1st Gen. Tacomas 1 02-04-2012 05:18 PM
WTB: first gen inside door handle return spring and side mirror adjustment handle beenjammin 1st Gen Tacoma Marketplace 0 09-28-2011 01:06 PM
Driver Door handle swap with Rear handle FL4x4Taco 2nd Gen. Tacomas 14 06-11-2009 05:37 AM
