03 Tacoma 2.4 liter...fuel pump relay location / long time no start question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hansel, Apr 18, 2013.
  1. Apr 18, 2013 at 7:15 PM
    Hansel
    Hansel [OP] Well-Known Member
    Glenn
    Arizona
    base
    My 2003 Tacoma 2.4 liter base truck has been sitting six months due to a wreck.
    I would like to start it, but think it would be a good idea to crank the engine without fuel delivery so that the oil pressure will build up. I figure this would help minimize damage due to a dry start... does that make sense?
    If so, can someone tell me where the fuel pump relay or fuse is located so I can temporarily pull it?
  2. Apr 18, 2013 at 7:17 PM
    Madjik_Man
    Madjik_Man The Rembrandt of Rattle Can
    Colorado Front Range
    1998 Ext Cab 3.4 4x4 TRD 5MT, 2004 DC 3.4 4x4 TRD
    I have a 98 3.4 but the relay is behind the lower dash panel next to/near the steering column.
    I've seen them where they are adjacent to the interior fuse panel (behind the lower dash) as well.
    Mine is stamped "circuit opening relay" on it.
  3. Apr 19, 2013 at 9:35 AM
    Hansel
    Glenn
    Arizona
    base
    thanks
    anyone know if the 4 cylinder has the relay in the same location as the 6?
  4. Apr 19, 2013 at 9:47 AM
    Madjik_Man
    It's literally two screws and two or three bolts to remove that panel and look it at it.
    1 minute tops.
  5. Apr 19, 2013 at 1:53 PM
    Hansel
    Glenn
    Arizona
    base
    thanks for the PIC
  6. Mar 23, 2020 at 2:28 PM
    kgw51gmc
    kgw51gmc Active Member
    2001 Tacoma 2wd, 2.4, 5 speed, 240K miles.
    Mod's include-- ONE upper left ball joint replacement, many mufflers, lots of tires and oil changes. ALL ORIGINAL. Owned for 13 years now.........
    Well my 2002 base model extended cab 2 wheel drive 2.4 5 speed Tacoma, I took those couple of screws off and looked at fuse panel. And there is nothing behind the fuse panel for a fuel pump relay I need to pump the five gallon can of diesel that got dumped into my Tacoma out and I have no freaking idea how to activate the fuel pump it should be so easy and I'm out here wondering how in the hell to do it and I don't think if I can find this stupid relay.
    Under the hood I got nothing too. Need help.
  7. Mar 23, 2020 at 2:33 PM
    kgw51gmc
    Here's a pic or two
    Tmaestas310 likes this.
  8. Mar 23, 2020 at 2:34 PM
    kgw51gmc
  9. Mar 23, 2020 at 2:34 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You really are going to a lot of trouble for minimum peace of mind. The truck can sit for years and have no damage because of oil starvation.
    Your truck already cranks to pressurize the oil system before the fuel is turned on and the plugs start firing.
  10. Mar 23, 2020 at 5:12 PM
    kgw51gmc
    Plus I can't hear the pump run when clicking key fwd. I sold my other Toyota last week and if was still here i could have compared.
