Suggestions... help...
Old 04-28-2013, 09:39 PM   #1
Grouse [OP] Grouse is offline
Grouse is on a distinguished road
Grouse's Tacoma Gallery
My 2002 Tacoma, 4 cyl, 4wd, 5 spd..... 276,000 still with original clutch...... I have a check engine light and it won't pass inspection until I get it looked at... it looks like a catalytic converter issue..... I also see it's running real rough out of no where.... essentially not driveable..... Question.... how much is it worth to spend on this..... it has a new frame (two years ago)..... I'm so attached to this truck but need to make decisions...... any ideas on a resell value with that mileage if I look for something newer..... thanks.....
Old 04-28-2013, 09:40 PM   #2
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
sounds like a miss. Get the code read for free at vatozone and see whats wrong.
Old 04-29-2013, 07:58 AM   #3
Wants to learn all about his Taco.
Taylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shedTaylor is one of the sharper tools in the shed
Taylor's Avatar
Taylor's Tacoma Gallery
We can suggest anything until you get the code read. take it to a parts store and get it read for free.
Old 05-03-2013, 08:02 AM   #4
It read misfire.... #2, swapped out coils and replaced "bad" coil with no improvement. I also had a badly worn wire yellow/green, third from left (of four) that broke completely.... might try to splice. Wish I knew how to post a photo here... I'll try.... any suggestions? Thanks to all!!!
Old 05-03-2013, 08:13 AM   #5
I spliced the other wire last year.... this one was barely holding on and leaves little room to splice. Anyone familiar with these or if this could be part of the problem? I'm going to replace the spark plugs tomorrow. The truck was tuned up a couple of years ago and they didn't replace a gasket and after I hit a puddle I found a misfire from water intrusion... replace plugs and it ran ok then.
Old 05-03-2013, 01:09 PM   #6
Stealth Custom Series™
SCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shed
SCSPerformance's Avatar
SCSPerformance's Tacoma Gallery
That looks like the harness for your MAF sensor. That broken wire could be the culprit to your misfire. I would definitely get that fix, reset the computer, and see how it goes.
looking for suggestions corndogg 2nd Gen. Tacomas 60 08-20-2011 05:10 AM
Name suggestions anyone? adamv22 2nd Gen. Tacomas 3 05-22-2011 12:21 PM
Suggestions anyone? GLOCKAMOLE 2nd Gen. Tacomas 22 01-27-2011 06:17 PM
i need suggestions!!!!!!!! white09taco 2nd Gen. Tacomas 9 10-01-2009 11:07 PM
any suggestions TACBOY Technical Chat 1 02-20-2009 10:31 AM
