Ignition Switch
Old 04-30-2013, 04:57 PM   #1
Newby [OP] Newby is offline
Newby is on a distinguished road
Newby's Tacoma Gallery
Ignition Switch
Hello,
I have a 96 Tacoma SR5 V6 4x4 with 262xxx Miles. There is no light comes on. The Ignition Switch was bad and every time I turned the Engine off, I could not turn the Ignition Switch to the Lock position so I could not pull the key out. I left the key in there in the ACC position for several days and the Battery was out then I could turned to the Lock position and pulled the key out as normal. Yesterday I just bought a new Ignition Switch from Toyota Dealer to replace it. Also I recharged the Battery, but after I finished installing the new Ignition Switch, I tested it and it worked fine, but it did the same thing as it did before with the new Ignition Switch. Do you have any idea why? I need your help please.
Old 05-01-2013, 06:51 PM   #2
Any idea, guys.
Old 05-04-2013, 08:11 AM   #3
It sometime works fine, but sometime it does not. Did any of you have the same or similar problem as I do now?
Old 05-06-2013, 03:29 PM   #4
Ray Beeze is on a distinguished road
Location: Conveniently located between Graceland and The Smoky Mountains
Ray Beeze's Tacoma Gallery
Automatic transmission?
Old 05-09-2013, 06:36 PM   #5
Yeah, it's automatic transmission.
I found out, not 100% sure, the problem is the key interlock solenoid.
Old 05-11-2013, 01:07 PM   #6
I had the same problem and found the shift lock control switch was bad. The transmission didn't know it was in park and wouldn't let the key turn to the off position. I umounted the console at the base of the gear shift and bypassed the switch; remounted the console and the ignition switch works fine now.
The only side effect is: you can shift out of park without having to depress the brake pedal and you can turn off (and remove) the key from the switch while the gear shift is in any position. Not necessarily a bad thing, just mentioning it.
Old 05-14-2013, 04:59 PM   #7
Great. It's a good reminding.
I removed the front cover (under the steering wheel) and unbolted the Key Interlock Solenoid for several days now and it works fine. In this case, can I just leave it unbolt and put the front cover back in? Is it safe?
Old 05-15-2013, 12:27 AM   #8
It shouldn't hurt anything. If the connector has any exposed contacts, tape them to prevent a short circuit and it shouldn't be a problem.
Lol, you and I operated on opposite ends of the same circuit: shiftlock control ecu sends impulse signal to the key interlock solenoid.
ignition switch von0777 2nd Gen. Tacomas 1 03-15-2013 08:49 PM
Ignition switch? key is acting up in ignition irwin billiot Technical Chat 3 06-23-2012 01:46 PM
Ignition Switch tinasnider 1st Gen. Tacomas 0 10-12-2010 05:04 PM
Ignition switch halo 2010TACO 2nd Gen. Tacomas 3 02-12-2010 10:28 PM
my ignition switch TacoBoss05 Technical Chat 3 12-16-2009 11:41 AM
