Will 8.4" axle shafts swap into an 8" E-Locker Axle?
Discussion in '1st Gen. Tacomas (1995-2004)' started by IDtrucks, May 2, 2013.
  1. May 2, 2013 at 9:19 PM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    As the title says, can I use the axle shafts from my 8.4 in a TRD 8" axle?
    I need a confirmed "yes I have done this and it swaps fine" or a "no i tried and it failed" type of answer haha.
  2. May 2, 2013 at 10:39 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well fuck, looks like I got my answer. Need new axle shafts as well.
    the 8.4 shaft is 28.25 and the 8" is 26.75
  3. May 2, 2013 at 10:55 PM
    TonyTacoBC
    TonyTacoBC Well-Known Member
    Tony
    Langley, BC
    '03 Reg cab 4cyl 4x4
    tires
    I swapped my axle shafts from my 8.4" axle to my 8" e-locker axle. They are the same length and use the same splines.
  4. May 2, 2013 at 10:59 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :confused::confused::confused:
    wait for real? Like you aren't bull shitting me? And they work fine? Did you do a swap? any pics?
    On 4 wheel parts they are different lengths. But they worked for you?
    8.4
    http://www.4wheelparts.com/Drivetra...?t_c=12&t_s=237&t_pt=5093&t_pn=G/295-2056-001
    8
    http://www.4wheelparts.com/Drivetra...?t_c=12&t_s=237&t_pt=5093&t_pn=G/295-2041-001
  5. May 2, 2013 at 11:05 PM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    Absolute truth! They worked perfectly! They're in my truck right now.
  6. May 2, 2013 at 11:06 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well...thats good to hear. should make for and easy swap if everything from the third out is the same or at least compatible.
    do you have any pics or a write up or anything about your swap? Im in the process of piling parts together to see if this is gonna be a reality.
  7. May 2, 2013 at 11:08 PM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    I think the page you're linking to is for axle shafts for older 8" axles. The 8" axle that came with the e-locker has the same axle shafts as the 8.4" axle.
  8. May 2, 2013 at 11:09 PM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    What model truck did your e-locker come out of?
  9. May 2, 2013 at 11:29 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    uuhhhh what model? It's a tacoma...honestly dont remember if its a 01-04 or older. I dont have it yet, hopefully ill get it tomorrow and take the third out and check for damage. The axle housing is bent, so I want to make sure the third is not damaged before I buy it.
  10. May 2, 2013 at 11:31 PM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    My e-locker axle housing came out of a '98 tacoma. My e-locker third came from a '04 tacoma. My axle shafts came out of my factory 8.4" axle that was in my '03 tacoma. It all went together perfectly :)
  11. May 2, 2013 at 11:34 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    lol basically what im planning on doing.
    Ill be comming back to you for advice haha
    :pray:
    please god give me a seamless swap
  12. May 2, 2013 at 11:48 PM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    PM me any time if you have any questions :)
  13. May 2, 2013 at 11:52 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Will do! Thanks!
  14. May 3, 2013 at 7:14 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Don't forget about ABS.
    Every E-locker I have seen has provisions for ABS, even when the truck does not have it.
    ABS shafts have a longer machined area for the bearing, 2 retainers and reluctor ring where the non ABS shafts have just a bearing and 1 retainer
    An E-locker rear will need ABS shafts.
  15. May 3, 2013 at 8:14 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    As long as both trucks don't have abs it could work i know the abs shafts have a slightly different taper and different spine count (i am pretty sure on this but you'll need to double check)
  16. May 3, 2013 at 8:28 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yes, sort of, it works as long as they are both ABS shafts.
    Marlin once made an adapter that would press into an ABS tube to allow the use of a non ABS shaft. The adapter just effectively reduced the size of the ABS tube and had a bore that would accept the non ABS seal in the non ABS location.
  17. May 3, 2013 at 9:12 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    So if Truck has abs and i don't have abs I still can't use my axle shafts? Fack. And there is no way around that ?
    Anyone have a pic of the differnece between the 2?
  18. May 3, 2013 at 10:40 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Here ya go.
    TRD E-lockers use the ABS shafts, a non ABS shaft will not work in an E-locker. I don't know how to say it any simpler.
    The ABS provision on the TRD can be spotted from the outside. On the topside of the ABS rear, right next to the backing plate there will be a bulge where the ABS sensor would go. Usually this spot is machined flat, drilled for the sensor and capped with a plastic plug secured by 1 bolt. In rare cases it is just the rough steel and not machined/drilled.
  19. May 3, 2013 at 10:55 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    So am I able to put a non abs seal in an abs housing and run the non abs axle? I dont see why not.
  20. May 3, 2013 at 12:09 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    No, go back and read post #16. Now look at your 2nd pic. It is hard to see but where the ABS seal sits, the bore of the tube necks down. That 1.5" or so of empty tube outboard of the seal has a diameter significantly greater than the O.D. of the seal.
    The O.D. of both seals is exactly the same and frankly, IIRC, they are the same seal. If not, they are real close.
    The adapter Marlin made was essentially a "reducing bushing" that pressed into the over sized ABS tube, reducing it to the appropriate diameter to accept the seal and locate it out at the end of the tube like your pic #1
    I don't think Marlin stocks this adapter or how much he gets for it but I am sure he would whip out a pair if that is the way you want to go. Give him a call.
