285 Clearancing
Discussion in '1st Gen. Tacomas (1995-2004)' started by JCH, May 4, 2013.
  1. May 4, 2013 at 9:39 PM
    JCH
    JCH [OP] Well-Known Member
    Justin
    Colorado
    2021 TRD Off-road
    Hey guys, so a couple days ago I got my 285/75/16 Hankook dynapro atm's on my 01 tacoma. We already did the pinch weld mod but still have a rubbing issue in the back side of the front fenders when i go over a bump while turning. I took the bolt out but it still does it. It shows where in the pic where. Ideas on how to clearance that? Does anybody maybe have some pics? Thanks
  2. May 4, 2013 at 9:53 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Dremmel tool, and cut more
  3. May 4, 2013 at 10:06 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Yup ^
  4. May 4, 2013 at 10:12 PM
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    Edit Wrong Section
  5. May 4, 2013 at 10:31 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    Where exactly should i cut though? What's behind that area?
  6. May 4, 2013 at 10:50 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Nothing that cant be painted black to match the rest of whats in your wheel well....:thumbsup: I got rid of my 285's because I wasn't comfortable with trimming the amount of material I thought needed to be taken out...looking back on it and after reading numerous builds on here since....It's not that big of a deal. Just take and trim the portion that you have marked...start there.
  7. May 5, 2013 at 6:15 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Just flex it out, mark what is hitting and then cut what you marked. Then flex it again and see if its hitting anywhere else. If it is then cut some more. Use a grinder with a cutoff wheel or dremel or whatever you have that'll cut it.
  8. May 6, 2013 at 7:48 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    So here what we ended up doing. We ended up just doing a cut in the plastic from the pinch weld mod over. Did it all with a utility knife which is a little hard on the fender flare but you can get through it. The part with the arrow to it was originally a mount for the mud flaps. Its a 90 degree bracket of sorts so we pinched the 90 degree bend together with pliers then with a ball peen hammer flattened it up flush against the wheel well giving more clearance. Then painted everything with rustoleum rust resistant paint. Haven't heard any more rubbing since
  9. May 8, 2013 at 11:56 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Hey thanks for this informative and documented thread. What offset wheels are you running?
    I've got a 4" backspace and am wondering if I can fit 12.5 width tires in there... Here's a pic of my trim job
  10. May 8, 2013 at 5:41 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    Honestly i have no idea what backspacing i have because I bought the wheels used.Anybody know a good way to measure? I do know that the tires rub the frame slightly at full lock, oddly though its only when turning right.
  11. May 8, 2013 at 5:43 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    One thing a did notice is that with this cutting it leaves a whole into the space in the door jam. Anybody had problems with rust from this?
  12. May 9, 2013 at 5:42 AM
    Lumpskie
    New Hampshire
    I'd be happy to share anything I've done. Could you zoom out a little with the picture? (I'm not sure exactly what location we're looking at)
  13. May 9, 2013 at 6:09 AM
    Southern01Taco
    Sean
    Holden, La
    Mine hasn't rusted yet. Just be sure to wash that spot out after you hit mud or anything because it definitely traps it.
  14. May 9, 2013 at 7:48 AM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    When you open the door it's the opening at the end by where the door hinges. I'll get a pic later today after school.
  15. May 9, 2013 at 6:06 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    Here's a more zoomed out pic.
    fb521c64-612d-4cdc-b8d5-07767a5cd844_zps_89a8ce4035d91ba5425b68d2944d160d21852d5f.jpg
  16. May 10, 2013 at 8:25 AM
    Lumpskie
    New Hampshire
    ^Wow... I never looked down there. I have to see what mine looks like now.
  17. May 10, 2013 at 10:05 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    What kind of rims are they?
  18. May 11, 2013 at 12:04 PM
    JCH
    Justin
    Colorado
    2021 TRD Off-road
    Niche
  19. May 11, 2013 at 12:32 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I had to trim out the majority of my inner splash guard
    as well...
    Yeah, the tires will throw up dirt, mud and little rocks
    an it tends to get packed in there.
    The solution would be to remove the fender
    and install some sort of deflector farther back.
    I temporarily used a pair of those foam
    insulation covers for gas pipe...
    and zip tied those to the hinges.
    Helps a little... but is not a permanent solution by any means.
    still find a coupla rocks and some dirt build up
    in the pocket area at the lower door jamb.
    So far the door seals have kept everything out.
    But I do have to spend a little extra time flushing rocks
    and dirt outta that area.
    Might be more of an issue for those living in the rust belt areas.
  20. May 11, 2013 at 10:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Somebody suggested spraying expandable foam in that gap. I have not tried it yet but it seems like it has potential. Depending on how fast it sets up, might be able to shape it/smooth it out on the side facing the wheel and seal up the gaps.
