Thermostat replacement question
Old 05-17-2013, 11:23 AM   #21
5280 [OP] 5280 is offline
old school
5280 is on a distinguished road
5280's Avatar
Gender: Female
5280's Tacoma Gallery
Well, got in the truck today and noticed right away that the temp gauge was AGAIN in the red. This after I paid for replacing the thermostat and a coolant change, to correct this very problem!
The shop will have to fix it, but I don't want to spend any more money there... After searching around TW and elsewhere I think maybe the problem is the ECT sensor... Has anyone else dealt with a similar problem?
Old 03-22-2014, 08:40 PM   #22
Coppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant futureCoppertone has a brilliant future
Coppertone's Avatar
Coppertone's Tacoma Gallery
Bumping for this phenomenon.
The temp on my SGII has ready 186-190 for the last couple of years. This weekend I did a timing belt / water pump / t-stat / etc.......all Toyota parts. I installed the t-stat with the jiggle valve at 12 o'clock as per the Hayne's manual, Safetydang's video, etc. Wouldn't you know....my temp is running at 198-202 now.
Tomorrow I will flip the t-stat to have the jiggle valve at 6 o'clock and report back.
Old 03-22-2014, 09:29 PM   #23
Robertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shedRobertgeejr1 is one of the sharper tools in the shed
Robertgeejr1's Avatar
Robertgeejr1's Tacoma Gallery
its still hard to say, now they could have put the thermostat in backwards, I have seen that more than once.
Now, one thing, do not let the motor overheat. one tip if she starts to run warm, throw your heater on high, its not much but it might help.
Old 03-22-2014, 09:31 PM   #24
Toyota4x46921 is on a distinguished road
Toyota4x46921's Tacoma Gallery
Mine was at 12 o'clock....scan gauge 202...6 o'clock runs 190.....
Old 03-23-2014, 07:30 AM   #25
Coppertone's Avatar
mind blowing.
Old 03-23-2014, 02:02 PM   #26
Coppertone's Avatar
I just moved it to 6 o'clock. Running 188 on the SGII now.
Old 03-24-2014, 03:45 AM   #27
JJ04TACO will become famous soon enoughJJ04TACO will become famous soon enough
JJ04TACO's Tacoma Gallery
Jiggle valve goes down. Search jiggle valve. There is a thread with links to the fsm that will tell you he same. As for the thermostat it is sooooooo easy. Did it and hoses in 30 minutes. I installed jiggle valve at 6 o'clock. When I removed the original it was at 7 o'clock. It's a one owner truck so I thought that was wierd. I did research and it goes down.
Question on replacement antennae spankeh Audio & Video 3 05-05-2013 12:49 PM
Thermostat? RedCamo5 1st Gen. Tacomas 7 02-10-2013 09:31 AM
Thermostat replacement bambooshoots 2nd Gen. Tacomas 1 08-26-2011 06:22 PM
HELP W/THERMOSTAT TacoStand 1st Gen. Tacomas 5 01-16-2011 01:03 AM
Timing Belt Replacement - Thermostat Question Yamasaki 1st Gen. Tacomas 7 05-31-2010 09:51 PM
