drivers side major sag after lift
Old 06-07-2013, 05:33 PM   #1
06yfz450ridr is on a distinguished road
06yfz450ridr's Avatar
06yfz450ridr's Tacoma Gallery
hey guys i have wierd problem and im not sure what needs to be looked at. i recently lifted my 97 tacoma 3 inch in the front (over coil) 2.5 in the rear( block and aal) and diff drop. it was nice at first until one day i noticed my front left making some noises over big bumps. the top of the strut actually is hitting the top of the wheel well on big bumps and seems to sag on flat level ground compared to the other side and the metal retainer on the inside is scraping the middle hole where it comes through as well as not being perfectly in the center. The strut does not appear to be bent at all since i replace the front and rear shocks and struts at the same time as the lift.
the thing is the old strut i took off that side was shot, that side was always bouncing like crazy on the highway as well as dipping alot.
Could it be the coil is bad from long time abuse with a bad strut? They were really old and you could tell they might have been only replaced once in the 160k miles since the rubber was dry rotted completely through them and resting on the metal.
also i am using no sway bar but i actually like it better without on the highway now
any help would be great
Old 06-07-2013, 08:01 PM   #3
RAT Products
isu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shedisu2014 is one of the sharper tools in the shed
isu2014's Avatar
isu2014's Tacoma Gallery
Did you get an alignment yet?
Old 06-07-2013, 08:02 PM   #4
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
I think you are missing some shock stem washers. See second item in this page:
http://www.wheelersoffroad.com/9504tacoadjbils.htm
Old 06-08-2013, 11:29 AM   #5
[QUOTE=KenLyns;6999045]I think you are missing some shock stem washers. See second item in this page:
http://www.wheelersoffroad.com/9504tacoadjbils.htm[/QUOTE
I know all the washers are on there. Now that I looked today its totally worse the rubberr piece is fully sticking through the hole now and the washers are loose that should be holding the coil. you can see the coil is bad its almost fully compressed now.
Old 06-08-2013, 07:47 PM   #7
bad side
you can see its not in the center like the other one, they were both in the center when i started
Old 06-10-2013, 08:22 AM   #8
wolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud of
wolfgang123's Avatar
wolfgang123's Tacoma Gallery
you didn't seat something correctly, remove struts, re-install the lift on both sides pretty much
Both sides appear to be installed wrong from the pictures
Rear suspension sag (passenger side) geolink Suspension 15 04-30-2012 11:47 PM
Driver side sag 5LUGTACO 5 Lug 13 03-15-2012 07:13 PM
drivers side tire rubs after new lift terrancej82 Suspension 3 08-02-2010 10:54 PM
left side sag tacoma2002 1st Gen. Tacomas 14 04-28-2010 10:35 AM
Rear suspension sag (driver side) 2006_TOY_TACO Suspension 18 06-23-2009 06:04 PM
