2001 tacoma 2.5 inch lift and tire question
Old 06-15-2013, 10:30 PM   #1
ryquic772 [OP] ryquic772 is offline
ryquic772 is on a distinguished road
ryquic772's Tacoma Gallery
i have a 2001 tacoma not a daily driver want to do a little cheap 2.5 inch lift on it with some new tires and rims..... the truck will be in mud alot and some trails and driven around town once in a whiile.....
heres the question what is the biggest tire i can run with the 2.5 inch lift?
is there a certain back spacing on rim or spacers to help fit bigger tires or certain size rim i should get like a 15 inch vs 17inch?
i would like to get close to a 33x12.5 might not be possible but just giving an idea of what i thinking and i dont mind at all cutting or bending panels away to fit the tires or even a little rub since it just a play truck....just seeing if i could get some help getting a little parts list together since idk much about it thanks alot guys!
Old 06-15-2013, 10:37 PM   #2
661prerunner has a spectacular aura about661prerunner has a spectacular aura about
661prerunner's Avatar
661prerunner's Tacoma Gallery
If you dont mind trimming you will should be fine. some do 35s on 3inches of lift
Old 06-16-2013, 11:04 AM   #3
To fit the 33x12.5 any idea what wheel spacing or rim off set u would need ?
Thanks for the reply
Old 06-16-2013, 12:01 PM   #4
I dont remember what I have But I want to say 4.5.
I have Fabtech C/Os set at like 2.75( dont quite remember I just wanted a lifted truck 5yrs ago) now Ive been fixing all my mistakes. and only rub frame at ride height.
I have since bought UCAs and Spindles and will trim after I install them. I havent wanted to trim due to not having my suspension done right to start
Old 06-16-2013, 01:33 PM   #5
ok thanks alot for the help just curious what u think should i do a lift like this http://www.summitracing.com/parts/tf...coma/year/2001
or just get the adjustale coils and blocks for the rear seperate?
thanks again appriciate it
Old 06-16-2013, 02:37 PM   #6
I run rear blocks now and I hate them. Stiff as all hell and are not good for already weak leaf springs. Get full leaf pack or aal
As for the front since you know your off roading I'd get something you can rebuild saves money in the end
Old 06-16-2013, 02:43 PM   #7
If go with this if you want spacers
http://toyteclifts.3dcartstores.com/...cks_p_309.html
Or. http://toyteclifts.3dcartstores.com/...cks_p_309.html
I've hated not having my suspension done right(what was only the rear block and coils crank to high from a shop. But it was also my lack of knowledge at the time). So I'd do it right the first time and also pick something you will be happy with
Old 06-16-2013, 06:40 PM   #8
thanks for all your help
Old 06-16-2013, 11:26 PM   #10
Run it
YotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shedYotaOverAll is one of the sharper tools in the shed
YotaOverAll's Avatar
YotaOverAll's Tacoma Gallery
I had 2.4 on mine with 33 12.50s with 4.5 backspacing. TRim the plastic, and beat the hell out of the pinch weld. Still gonna rub a little bit though. A lot if you're turning and hit a bump fast.
Biggest 17 inch tire with 3 inch lift Gloade16 Wheels & Tires 23 02-05-2015 06:43 AM
Noob 2001 taco tire/lift/suspension question....for the experts damonwatson Suspension 1 12-18-2011 09:53 PM
another tire fitment question w, procomp 3 inch lift stunt man hans Suspension 19 08-28-2011 07:34 PM
Max tire size on my 07 tacoma with 3 inch lift? Bkarol91 Wheels & Tires 1 03-20-2011 11:26 AM
15 inch wheels fit on my 2001 trd 4x4 tacoma??? carsonc1974 Wheels & Tires 12 09-27-2010 06:40 PM
