3.4L misfiring on cylinder 3 and 4
Old 06-19-2013, 06:11 PM   #1
fourthtaco [OP] fourthtaco is offline
fourthtaco is on a distinguished road
fourthtaco's Tacoma Gallery
During accelerating fairly hard to go around a stalled vehicle, my 2003 started missing/running rough. Scanner showed P300, P303 and P304. What would make 3 and 4 start misfiring all of a sudden like that? Thanks for your help.
Old 06-19-2013, 06:29 PM   #2
Ace of Spades
Alderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shedAlderleet is one of the sharper tools in the shed
Alderleet's Avatar
Air Force: OPSEC
Alderleet's Tacoma Gallery
I had the same exact problem one day.
Im not entirely sure what caused it either. Its like the 2 cylinders decided to cough and die.
I seafoamed hte engine afterwards, and changed the EGR valve, and it hasnt happened again...
Old 06-19-2013, 06:45 PM   #3
Beee1985 is on a distinguished road
Beee1985's Tacoma Gallery
Check your spark plugs and spark plug wires, make sure they are not broken or nipped. I had this problem with my Camry.
Old 06-20-2013, 07:30 AM   #4
Inverno4 is a splendid one to beholdInverno4 is a splendid one to beholdInverno4 is a splendid one to beholdInverno4 is a splendid one to beholdInverno4 is a splendid one to beholdInverno4 is a splendid one to beholdInverno4 is a splendid one to behold
Inverno4's Tacoma Gallery
Check your ignition coil. Same issue I had and that fixed it
1998 3.4L 5-speed Clutch Master Cylinder Removal Madjik_Man Technical Chat 0 05-19-2013 11:30 AM
'00 3.4L Cylinder 1,3,5 codes. Help! Alderleet 1st Gen. Tacomas 6 05-03-2012 05:06 PM
Engine seems to be misfiring? taco_24 2nd Gen. Tacomas 0 05-20-2011 05:57 AM
cylinder #3 misfiring j.porter Technical Chat 0 01-16-2011 12:32 PM
Rough Idle and Misfiring #4 cylinder nizzledizzle 1st Gen. Tacomas 15 01-30-2009 09:11 AM
