03 2.7 hard to go into 1st after new clutch
Old 06-28-2013, 09:03 PM   #1
Twesty32 [OP] Twesty32 is offline
Twesty32 is on a distinguished road
Twesty32's Tacoma Gallery
I just installed a marlin 1600 heavy duty clutch in my 2003 Tacoma. I also had to replace the clutch fork and pivot, the truck would barely go into gear before, you would have to shut it off sometimes to get it to go into 1st. before all that it shifted fine and went into first just fine. also I resurfaced the flywheel. now the truck is hard to get into first, it does not grind or anything it just doesn't want to go in. I lubed the throw out bearing and clutch fork, also I have bled the slave cylinder and changed the clutch fluid, the trans fluid is new also. I don't think it is a slave or master issue because it doesn't grind. I was wondering what you guys thought it might be?
Thanks a lot,
Tim
Old 06-28-2013, 09:40 PM   #2
Bash Fabriction & Off-Road
01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed
01Tac0ma's Avatar
01Tac0ma's Tacoma Gallery
Mine did this after I first put the same clutch in, the throwout bearing had come off the clips and been destroyed.. might want to take the rubber grommet off driver side and take a peek inside to be sure its still on the clips correctly
Old 06-30-2013, 07:54 PM   #3
It does grind when i push the cluch in, it just seems like it doesnt want to go into first. Im going to pull the cover off and take a look this week. It has got me stumped.
Old 08-25-2013, 11:17 PM   #4
its not the throw out bearing, it all looks good. idk what is causing it
Old 08-25-2013, 11:21 PM   #5
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Does the slave cylinder move that fork enough?
Try bleeding it again.
Truck hard to start because of touchy clutch Priddle 2nd Gen. Tacomas 2 04-09-2012 07:50 PM
I have to push REALLY hard on my clutch to turn on.. xwillx93 2nd Gen. Tacomas 3 12-10-2011 08:18 AM
having a hard time finding clutch replacement info jeffz0rz 4 Cylinder 9 05-09-2011 09:31 PM
'03 tacoma clutch? thwocka 1st Gen. Tacomas 11 11-26-2010 11:15 PM
hard tu push clutch pedal cuaco72 1st Gen. Tacomas 11 11-16-2010 05:26 PM
