Who makes the best rear frame strenthening plates?
Old 07-02-2013, 06:57 PM   #1
xcmtb83 [OP] xcmtb83 is offline
xcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shedxcmtb83 is one of the sharper tools in the shed
xcmtb83's Tacoma Gallery
I am wanting to beef up the back of the frame while I have the box off so first of all who all makes these reinforcement plates?
Who makes the best rear frame strengthening plates?
Can they be added without additional fabrication e.g. shock mount relocation, etc.
Thanks for the input.
Old 07-02-2013, 06:59 PM   #2
Solid Axle FTMFW!!
Supra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shed
Supra TT's Avatar
Supra TT's Tacoma Gallery
The best ones are the homemade ones, because you did it yourself!
However, they are all pretty much the same, just some plate that has cut outs in it. Yes they can be installed with no modifications at all. Just slap em one their and weld. (Well obviously grind the frame down clean! )
Old 07-02-2013, 07:25 PM   #3
The Rembrandt of Rattle Can
Madjik_Man's Avatar
Madjik_Man's Tacoma Gallery
45acp and I got my plate from a scrap yard. Paid like $8 or something for enough metal for both sides
Old 07-02-2013, 07:42 PM   #4
How do the side plates like the ones pictured compare to the boxed frame kits I have seen around?
BTW that plate looks nice!
Old 07-02-2013, 07:44 PM   #5
Madjik_Man's Avatar
I'd imagine quite well.
A lot of guys who carry a lot of weight in the rear (armor, RTT, etc) use the outer plate method (or whatever it's called)
Old 07-03-2013, 04:12 AM   #6
Countinuous improvement
TejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shed
TejasYOTA's Tacoma Gallery
If you box your frame - - it will be stronger than just thickening one wall section.
But that all depends on the thickness of the material you use and how well is your welding skills.
If I had the time, I would had boxed my frame.
Old 07-03-2013, 04:22 AM   #7
My drinking team has a wheeling problem
V5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shed
V5ioV's Avatar
V5ioV's Tacoma Gallery
a guy in the NJ BS Thread is about to install this "Trail Gear" BOX kit http://www.trail-gear.com/tacoma-rear-frame-box-kit
Not sure if its the Best though… its 3/16'' so i assume if you find a thicker one that would be consider "better" also, i know nothing about welding, but i assume that proper welding its just as important as the plates…
good luck!
Old 07-03-2013, 10:25 AM   #8
Neighborhood Know-it-all
Box Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shedBox Rocket is one of the sharper tools in the shed
Box Rocket's Avatar
Box Rocket's Tacoma Gallery
3/16" plate is plenty for frame plating or boxing. It's thicker than the stock frame. Boxing the frame will be stronger than outer frame plates, but either will work and help to keep your frame from bending after the addition of weight over the rear of the truck.
As for which ones are best? Not a whole lot of difference in the plates themselves. It will come down more to the quality of your welds.
One suggestion I'll make with outer plates. If you don't fully weld around the perimeter (like the ones Madjik_man posted) I think it's a good idea to use some seam sealer in the areas around the edge where there isn't a weld. That will help to keep moisture out from between the plates and the frame. Otherwise you can develop rust between the plate and frame which will eat through the frame quicker than if you didn't have plates at all.
Old 07-03-2013, 10:37 AM   #9
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
I was thinking the same thing looking at that picture.
Old 07-03-2013, 11:47 AM   #10
Madjik_Man's Avatar
Already ran a bead of silicone adhesive around the non-welded areas. Should hold up fine IMO
Old 07-03-2013, 12:55 PM   #11
Box Rocket's Avatar
Silicone will be fine but it attracts dirt and the dirt sticks to it. It washes off fine, but just looks dirty most of the time. Seam sealer is stronger and doesn't attract dirt.
Old 07-03-2013, 02:28 PM   #12
Madjik_Man's Avatar
Why don't I confer with you before I do anything?
I suppose I can dig this sealant off and get seam sealer, I suppose. Do they make it in black?
frame strengthening plates, do or don't?? logan1992 1st Gen. Tacomas 33 07-16-2013 04:57 PM
Beefiest frame plates License2Ill 1st Gen. Tacomas 5 01-22-2013 09:48 PM
1st Gen rear frame reinforcement plates Group Buy closes 8-1-2011 at 12:00am JLee Group Buys 342 08-19-2012 03:17 PM
Frame Reinforcement plates NegroTundra 1st Gen Tacoma Marketplace 20 09-27-2011 03:40 PM
Frame Reinforcement Plates.. 08pretaco Suspension 0 08-03-2010 12:14 PM
