Gear Shifter Leather Boot to Carpet Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by yote, Jul 6, 2013.
  1. Jul 6, 2013 at 2:40 PM
    yote
    yote [OP] Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Leather Boot Replacement with Black Carpet
    GOT THIS NEAT IDEA FROM HIGHERLUX
    What it (roughly) looked like before:
    What it looks like after:
    THE MOD
    You're gonna need: your black carpet, a sharpie, razor, a staple gun, a set of pliers, a set of needle nosed pliers, a measuring tape (and/or ruler), as well as some sort of good scissors that can cut carpet easily.
    FIRST cut away the leather boot that attaches to the metal rectangle guide for the plastic trim.
    Here are the dimensions of my template I used (it's not pictured in the phases of this project) just FYI:
    1.) You're gonna need to make an initial carpet cut out, taking the length of the sides into account (roughly 6cm):
    2.) Next figure out the dimensions of the rubber boots after you have lifted the bottom up! It's smaller underneath the bottom lip of the boots:
    3.) Center your template and mark where the shifters will sit:
    4.) You will then cut the corners by using the metal rectangle as your guide.
    5.) When you start stapling the carpet to the metal rectangle, try and use up as little carpet as possible so you will have more room to work with when you go to put your rubber boots through your 2 holes.
    BEFORE THIS STEP- I would strongly suggest making sure your holes are the perfect fit for the boots before you start stapling
    6.) When stapling the sides, try and work your way from the outside inward:
    7.) Start on your 1 side and then work your way around until they are all getting stapled down:
    8.) Half way done/in progress stapling:
    9.) All 4 sides stapled:
    TOP
    BOTTOM
    10.) When inserting into your plastic trim, use your sharpie and mark where the metal rectangle is supposed to clip into the plastic trim:
    11.) Use your razor and shave off a piece of that portion of your carpet so the metal rings can grab the plastic teeth on your trim piece to attach back up there-- do this for all 4 corners and it should fit (quoting Ace Ventura) "mmm like a glove":
    12.) The final fitting:
    The Finished Product​
    I haven't made many DIY threads but I thought this mod looked too good NOT to share it with this forum! If you have any questions about this mod then don't hesitate to ask. Thanks for looking!
    OffroadToy and wellsf like this.
  2. Jul 6, 2013 at 2:42 PM
    JMaberry
    JMaberry Well-Known Member
    Jack
    Salt Lake City, Utah
    01 3.4L TRD SR5 Extended Cab
    Spectre Intake, custom exhuast, ultragauge, bedlined bumpers and grill, ARE shell, jvc headunit, bottle opener in bed, satoshi, hella 500ffs behind grill
    Looks great, I like it! I've never been a big fan of the stock leather shifter boot.
  3. Jul 6, 2013 at 11:18 PM
    yote
    Mark
    Tacoma, WA
    Thanks! Yeah I was never a fan of that leather boot, all it did was get grungy over time, this looks better IMO and you can store all the same crap down there that you normally would with the leather boot
  4. Jul 9, 2013 at 8:44 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    looks alot better than mine does, good job dude :thumbsup:
  5. Jul 10, 2013 at 11:41 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    07 Lexus GX470
    That turned out great, you could also use neoprene to set it apart from the rest of the carpet.
    voodoomaster33 likes this.
  6. Jul 10, 2013 at 1:28 PM
    yote
    Mark
    Tacoma, WA
    Thanks! You're the brains of this mod.
    Very true, it's a pretty easy mod, just very time consuming especially with the stapling. If you choose to try with neoprene be sure and post a few pictures here so we can see!
  7. Jul 16, 2013 at 9:42 PM
    MEDICDUDE423
    MEDICDUDE423 Well-Known Member
    East TN
    03 Tacoma Limited X-Cab 4WD
    Good Job Bro
  8. Jul 16, 2013 at 9:47 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Subb'd may have to do this with my 4x4 shifter it looks good, and where did you get the new shifter covers?
  9. Jul 16, 2013 at 10:05 PM
    yote
    Mark
    Tacoma, WA
    Are you talking about the rubber boots at the bottom of the 5-speed shifter & 4wd shifter?
    If so, they're currently underneath your leather shifter boots
  10. Sep 16, 2013 at 12:30 PM
    yote
    Mark
    Tacoma, WA
    An update I didn't think of: Those with the 4wd button on your 2nd shifter... you might have to figure something out with the wire that runs down that shifter from the "4wd" button. Just an issue my Dad ran into when considering this mod for his 2002 Tacoma.
    Thanks, looks so much better than the leather boot
  11. Feb 9, 2014 at 3:34 PM
    WThomas1250
    WThomas1250 Well-Known Member
    Bump! Just found this thread. I'm gonna try it with neoprene tomorrow if I can find the fabric. I'll post pics if it turns out halfway decent :D
  12. Feb 27, 2014 at 11:27 AM
    pnwtaco
    pnwtaco Well-Known Member
    Taylor
    Bellingham, WA
    95 3.4 manual 4x4
    Bilstein 5100's, Pro Comp alloy rims with 33" Duratracs
    Totally just did this, love it. reminds me of my 94 p/u
  13. Jun 24, 2014 at 7:18 AM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    I think once I get my new black interior carpet installed I'm going to end up doing this mid.
    Great write up and definitly plan on doing this.
  14. Jun 24, 2014 at 7:30 PM
    yote
    Mark
    Tacoma, WA
    Did you end up doing it?
    Turned out awesome! :thumbsup:
    Thanks, so much better than the leather look! Try and post some pics when you do it, I always like seeing other people when they do it
  15. Jun 24, 2014 at 7:37 PM
    yote
    Mark
    Tacoma, WA
    San Diego area. Got done with a 2 month long school a few weeks back and now I've been in adjusting to my new unit here at Pendleton so I'll be a frequent TW user again :) ...... but no more WA meets for a whiiiiiiiile :(
  16. Jan 9, 2015 at 10:53 PM
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Bay Area, California
    01 tacoma sr5 trd 4x4 5speed
    Camper Shell Thule System 3 inch lift procomp wheels km2's apex plate bumper piaa lights warn m8000-s
    I like this! Adding it to the list.... You have a build thread for your new truck?
  17. Jan 10, 2015 at 12:23 AM
    yote
    Mark
    Tacoma, WA
  18. Jan 10, 2015 at 9:21 AM
    bayareataco
    Jimmy
  19. Sep 8, 2021 at 2:39 AM
    Less4Than8Jake
    Less4Than8Jake New Member
    Jim
    Cumberland RI
    2004 Silver Tacoma TRD
    For the most part it has been restored to new working condition. Now the fun can begin.
    I just did this to my truck this weekend. Thanks for posting it, looks great!
  20. Sep 8, 2021 at 3:40 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I may do this and wrap the metal shift lever parts in paracord. That’ll make it look better since I have the push button 4x4
