Fuse Box/Ballast Mounting Idea help
Old 07-24-2013, 06:48 AM   #1
StAndrew [OP] StAndrew is online now
Wait for it...
StAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shed
StAndrew's Avatar
Navy: SWO
StAndrew's Tacoma Gallery
Got my lights and switch mounted but need ideas on where to mount my fuse box and ballast.
The driver side under the hood is too crowded with the alarm and auto start system.
Im thinking of mounting in the cabin but not sure where. Any ideas would be great. Otherwise, it will be mounted on the passenger side close to where the air box is.
Thanks.
Old 07-24-2013, 09:14 AM   #2
I deal with dead animals
meatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shed
meatman's Avatar
meatman's Tacoma Gallery
I mounted mine on the passangers side but i did'nt have any abs in the way
I remember another member mounted his in the lower center colsole. I forgot who it was tho
Old 07-24-2013, 11:55 AM   #3
Wait for it...
StAndrew's Avatar
Navy: SWO
How much extra wiring did you need to mount it on the passenger side?
Old 07-24-2013, 12:49 PM   #4
meatman's Avatar
It took around 8ft. to run from the battery to the passanger side. I had a little left over but not much
Old 07-24-2013, 06:46 PM   #5
Countinuous improvement
TejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shed
TejasYOTA's Tacoma Gallery
Check my install...on the fuse box under the hood.
Only place I could mount near the battery.
http://www.ttora.com/forum/showpost....9&postcount=44
Old 07-24-2013, 06:48 PM   #6
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
Mine is mounted on the passenger side beside the cc module
Old 08-03-2013, 08:12 PM   #7
Hey Now!
w00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shed
w00dy's Avatar
w00dy's Tacoma Gallery
Such a clean install! Im assuming you left enough cable slack to be able remove the fuse box lid incase you need to access the fuse block?
Old 08-04-2013, 06:07 AM   #8
yes I did.
There is even a trapazoid cut out on the plate to allow the plastic tab to operate correctly.
The mounting screws were also placed to not to interfere with any parts under the factory fuse box cover.
Fog light Ballast mounting BnbBlitz 2nd Gen. Tacomas 4 04-26-2013 12:55 AM
'01 Taco DC: Fuse Box. Relay Box and Circuit Breaker TejasYOTA 1st Gen. Tacomas 15 03-21-2013 01:26 PM
Blown AM1 fuse in under hood fuse box Gameload1187 Technical Chat 2 01-02-2012 08:57 AM
Need idea for mounting box in bed evile 2nd Gen. Tacomas 15 09-22-2010 08:45 AM
HID Ballast Mounting CJH9980 2nd Gen. Tacomas 2 12-03-2008 03:43 PM
