problems w/ blown head gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by jb22384, Jul 25, 2013.
  1. Jul 25, 2013 at 5:31 PM
    jb22384
    jb22384 [OP] Member
    Georgia
    97 4WD V6 Ext. Cab
    the head gasket in my 97 tacoma has blown. should i have it repaired or have a new (to me) engine installed?
  2. Jul 25, 2013 at 5:43 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I would pick up another motor. It's cheaper and quicker and I could do it myself, but that's me. Unless you've done extensive work on your truck, spending a pile on a newer motor is foolish IMO.
  3. Jul 26, 2013 at 8:49 AM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    It all depends on how comfortable you are tearing it apart on your own. If you are comfortable and capable of doing so, it will be the cheaper route to go, given you're not paying for labor charges. But, if you're not comfortable doing so, I'd look into both options: repair or replace.
    Other things to take into consideration are:
    -How long was it overheating for before it blew? Could lead to warped heads/block, which requires further work or replacement
    -How many miles are on it and how well has it been maintained? Have you invested enough TLC into it to make it worth salvaging?
    -How much is a used take out motor from a like vehicle? If you score a decent priced one in decent condition, it may be cost effective overall (factor in R&R labor, of course).
    Many decisions to make. Only you, or your mechanic, if you have one, truely know your engine and how well it's been cared for. That little piece of knowledge can be a big deciding factor. Good luck!
