Lower Ball Joint-replacement
Old 08-24-2013, 03:24 PM   #1
TejasYOTA [OP] TejasYOTA is offline
Countinuous improvement
TejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shedTejasYOTA is one of the sharper tools in the shed
TejasYOTA's Tacoma Gallery
Talking Lower Ball Joint-replacement
Replaced my 160,000 mile Lower Ball Joints this morning... about 2 hrs work.
Super simple.... now it is good for another 100,000 plus miles of fun on the trails!
Original... the torn boot was when I removed it.
New factory version.
Not going to bore you all about the install... I have it written up on my TTORA Garage Section.
Old 08-24-2013, 04:22 PM   #2
EASY WIND
Dirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shedDirty Pool is one of the sharper tools in the shed
Dirty Pool's Avatar
Dirty Pool's Tacoma Gallery
OEM, way to go. I'm steeling your pic for my data/image base.
Now is the perfect time to put a dab of something across the bolt head/joint body so you can tell at a glance if any loosening is going on.
Here JBWeld epoxy is used cause that's what was laying around and it's kinda thick. It's not there to secure anything, just to give a good visual if the bolt has moved, before they shear.
Old 08-24-2013, 04:53 PM   #4
EASY WIND
Dirty Pool's Avatar
Originally Posted by Konaborne View Post
is the bj just held on by a castle nut and pin?
I gotta swap mine sometime
Ball joint to LCA by the castle nut.
Ball joint to spindle by the 4 bolts notorious for loosening then shearing.
Look at the pics above.
Old 08-24-2013, 05:58 PM   #5
Good idea... need to get a new tube of JBW anyways.
When you did yours, did you also used the BLUE Loctite?
Old 08-24-2013, 06:50 PM   #6
EASY WIND
Dirty Pool's Avatar
Yea, plus I am a little nuts (maybe very nuts), definitely senile.
Specifically for the 4 mount bolts, 1st I run a dull tap through, then a solvent laden gun bore brush followed by comp air. Additionally OEM joints have a preservative coating on the machined seat areas that should be removed (sometimes it's pretty thick, with thicker runs and blobs), then comes proper torque with Loctite. And as if that's not enough I dribble some Permatex "AfterLoc" on the tops of the bolts where they stick out of the spindle. If I have to service a CV shaft or something, I pop the ball joint stud and leave the bolts alone. I consider them borderline 1 time use fasteners.
Permatex AfterLoc is some handy stuff. It's a penetrating thread locker made for after torque applications. I use it just to tell myself I did all that could be done. It is great stuff however, for fasteners that might benefit from "torque > thermal cycle > re-torque" then thread locker. EDIT, like rear diff carrier nuts.
Good luck with your stay in "sick bay".
Old 08-24-2013, 07:10 PM   #7
Pineapples on pizza Hawaiian does not it make.
Konaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shed
Konaborne's Avatar
Konaborne's Tacoma Gallery
Ball joint to LCA by the castile nut.
awesome, thanks
didn't know if there was something else holding the bj into the lca///if it would be as much of a PITA to swap as the uca haha
Old 08-24-2013, 09:40 PM   #8
4WD 4WD is offline
cRaZy oLdmAn
4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed
4WD's Avatar
4WD's Tacoma Gallery
awesome, thanks
Dammit Cody !! Don't make me break out the pics that show the horror of failed LBJ's
LR UCAs: ball joint replacement, ball joint hitting coils Chickenmunga Suspension 37 08-20-2013 05:36 PM
Lower ball joint replacement or whole lower control arm? Swamp Donkey 2nd Gen. Tacomas 4 04-29-2013 11:57 PM
Lower Ball Joint Replacement. BlueTaco07 2nd Gen. Tacomas 1 01-27-2013 06:32 PM
Lower Ball Joint Replacement Questions? RacerP 1st Gen. Tacomas 11 06-12-2012 07:55 AM
Left Lower Ball Joint Replacement? Pismo 2nd Gen. Tacomas 3 11-26-2011 09:36 PM
