Turbo Kit
Old 08-31-2013, 10:55 PM   #62
x2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shedx2468 is one of the sharper tools in the shed
x2468's Avatar
x2468's Tacoma Gallery
Originally Posted by Blackdawg View Post
Huh never seen that. But that looks like it's an intercoller for the snorkel? Or is it for the turbo?
Yu can make any intercoller work with the right tubing work.
I had to double check, but it says "Matched to the turbocharger air delivery in lb/min".
I see what your saying but what I was thinking is like, would it cool the air enough to be worth it, or would it require so much irregular pumping that it would kill to much performance. I guess it's hard to know just by looking at it.
Old 08-31-2013, 11:43 PM   #64
x2468's Avatar
The way I thought of making the snorkel working is somehow making the stock air box still work just to hose a cone filter and cut a bigger outlet to fit to the turbo.
Would a traditional intercooler survive off-roading?
Old 09-01-2013, 12:28 PM   #67
x2468's Avatar
Originally Posted by Torspd View Post
You'd have to find a way to mount it. That is specific to the Landcruiser 70 series. They do have some cool stuff for those diesel Toyotas though.
Yeah I was just wondering because, aside form being designed by safari for the snorkel and probably more rugged, it also looks pretty compact. The intercooler in the CXracing pics looks pretty low slung for such a soft metal (it's aluminum right) and also looks like it would interfere with an off-road bumper or winch mount.
Idk, just thinking out loud, and trying to give anyone with deeper pockets than me some ideas.
Old 09-02-2013, 06:12 AM   #69
AddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud ofAddictedOffroad has much to be proud of
AddictedOffroad's Tacoma Gallery
Here are some pics of ours.
3.4L Turbo'd
Current ride height now. This is MUCH lower than when first finished.
Old 09-02-2013, 10:05 AM   #71
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
I would think for the $10k it would be cheaper to put an LS1 in the engine bay! lol.
Old 09-03-2013, 01:20 PM   #73
DHwreckage is a splendid one to beholdDHwreckage is a splendid one to beholdDHwreckage is a splendid one to beholdDHwreckage is a splendid one to beholdDHwreckage is a splendid one to beholdDHwreckage is a splendid one to beholdDHwreckage is a splendid one to behold
DHwreckage's Avatar
DHwreckage's Tacoma Gallery
Hey scotty can you post up a few specifics like the turbo size, psi your running and what fuel mods you have with it?
Old 09-03-2013, 01:37 PM   #74
Wait for it...
StAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shedStAndrew is one of the sharper tools in the shed
StAndrew's Avatar
Navy: SWO
StAndrew's Tacoma Gallery
if done right i don't see why not..
With high engine load and low air flow, may want to consider an electric fan mounted on intercooler .
3.4L Turbo'd
This. And WHP? CXRacing claims 300-500 WHP which I find a bit optimistic...
Old 09-03-2013, 05:48 PM   #75
x2468's Avatar
3.4L Turbo'd
The times, they are a changin. What's the price on the plumbing for this?
Old 09-03-2013, 08:51 PM   #77
x2468's Avatar
Based on the two most documented 5vz turbo's, with homemade builds which produced 350-400Hp and 450-500Tq, I would guess in that range. With cams, forged pistons, new gaskets, head studs and proper engine/fuel management though..... who knows?
Old 09-03-2013, 09:33 PM   #79
x2468's Avatar
The only guy i've seen try twin charging was this guy http://www.whyturbothat.com/srunnermain.html Ctrl+F it. It didn't run very well.
From what I gather, a 5vz shouldn't have trouble spooling a turbo at low rpm as long as it's a modern brand name turbo and it's the right size.
New turbo kit kickergt 1st Gen. Tacomas 24 12-18-2013 10:05 AM
Turbo Kit or Super charger kit For 2.7L??? SkyGuy19 Performance and Tuning 12 05-12-2013 06:59 PM
2rz turbo kit mjbtaco 1st Gen Tacoma Marketplace 12 07-14-2012 09:11 AM
Homemade turbo kit! (LOOK HERE!) Who Dat Popcorn Off-Topic Discussion 15 06-27-2011 12:07 PM
Turbo: is there a complete kit out there? patrickockander 2nd Gen. Tacomas 44 01-02-2010 07:18 PM
