Coolant Leak... :( Found it
Old 09-02-2013, 10:08 AM   #1
Hillbilly
Fenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shedFenwick1993 is one of the sharper tools in the shed
Fenwick1993's Avatar
Fenwick1993's Tacoma Gallery
Went to check Stonewall's antifreeze two days ago, found that there was nothing in the reservoir. I thought this was very strange, because when I checked it last week, it was within level. I bought some undiluted dexcool (what I already had in the system, of course) and diluted it myself. (I refuse to pay for 50/50 when I've got water at my house I can mix it with) Topped it off to the full line on the reservoir, let it burp down threw some more in until it was full again, and I've been watching it. In two days, it has dropped down to this:
Unable to find the leak because the coolant had been thrown everywhere, I cleaned everything off with a rag and drove around the neighborhood until my fan came on. Stopped on the side of the road, put on my hazards, and popped the hood. Couldn't see it. Turned the truck off, and still couldn't find it. Wasn't leaking yet, I guess. So I drive back to the house and park out front. Turned it off, gave it a bit, and lo and behold, I done found it.
Old 09-02-2013, 06:24 PM   #3
Rich91710's Avatar
Rich91710's Tacoma Gallery
Originally Posted by tacomataco2 View Post
Put some stop leak in it lol
Old 09-02-2013, 08:41 PM   #4
Hillbilly
Lol, wouldn't trust that anyways. I'll let y'all know what's going on with this as soon as I do more about it.
Old 01-20-2014, 09:50 AM   #5
bmka87 is on a distinguished road
bmka87's Avatar
bmka87's Tacoma Gallery
Old thread, but just found today had a bunch of little red drips in the fresh snow underneath the passenger side blinker. Tried to follow the path but couldn't really see a lot. Need to take it out and get it warm to see if I can spot it better.
OP did you have any luck with this issue??
Old 01-20-2014, 09:52 AM   #6
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
Could be a tank seeping on the radiator or a hose leaking being on the passenger side. I had a tank begin seeping on me.
Old 01-21-2014, 12:08 PM   #7
bmka87's Avatar
I'm still learning about how to fix this stuff and I'm not really sure what the tank is? You aren't talking about the overflow tank right? That's located on the oposite side...
Old 01-21-2014, 12:09 PM   #8
Hillbilly
I found what I thought to be the source of the leak- looked like the thermostat housing on the side of the block. I put a new gasket in right there, but the leak is still there. :/
Old 01-21-2014, 12:13 PM   #9
bmka87's Avatar
That's too bad! Once this real cold snap breaks here I'm hoping to get out there and see if I can tell where it's coming from.
Old 01-21-2014, 12:17 PM   #10
Hillbilly
Man, it's nuts! It was 64 here earlier, now it's down to like 45, and is going to be 15 by the end of the night.
Old 01-21-2014, 12:32 PM   #11
The radiator has 2 tanks. Either on top and bottom or side to side. A big hose connects to each one and then to the motor.
Old 01-21-2014, 04:55 PM   #12
bmka87's Avatar
Thanks for the tip, I'll check this out hopefully within the next couple days.
Sounds pretty similar!! Woke up this morning and it was 5*.....doesn't make looking for a leak outside any easier!
Old 01-22-2014, 09:36 AM   #13
Hillbilly
And now there's snow everywhere... go figure!
Old 01-25-2014, 09:30 AM   #14
bmka87's Avatar
Finally found the leak, and it isn't a coolant leak. With the new extreme temperatures here in Maine the leak had actually stopped. Today it actually hit 23*, heat wave, so things started leaking again. Followed up and actually it's my washer fluid, just looks very similar to the pink antifreeze in the snow (I use that orange rainex fluid).
Old 01-25-2014, 10:24 AM   #15
Counterpart is a splendid one to beholdCounterpart is a splendid one to beholdCounterpart is a splendid one to beholdCounterpart is a splendid one to beholdCounterpart is a splendid one to beholdCounterpart is a splendid one to beholdCounterpart is a splendid one to beholdCounterpart is a splendid one to behold
Counterpart's Avatar
Counterpart's Tacoma Gallery
Just a quick tip based on my knowledge of General Motors products, beware of using Dexcool in your Toyota's. It is know to be corrosive of Aluminum. That is a fact.
Sometime's it is worth using factory recommended products.
FYI.
Old 01-25-2014, 11:23 AM   #16
Old & Forgetful
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
For those of you with leaks.... when was the last time your water pump was changed??
The water pumps are held to the block via bolts & RTV. The RTV will break down and cause a leak. I had the same issue in my 96 (many years ago).
Old 01-25-2014, 11:44 AM   #17
Hillbilly
FYI.
Really? I did not know that. I've been running Dexcool. Looks like I'll be switching over to regular after hearing this.
I did not replace the water pump when I rebuilt the engine. I just slapped new bearings in it, cleaned up the valves, etc. So water pump has just over 149000 miles on it. Seems like about time to replace it, but I can't do that until I can afford it.
Old 04-17-2014, 06:04 PM   #18
blazintowers is on a distinguished road
blazintowers's Avatar
blazintowers's Tacoma Gallery
I have radiator tank leaking on my 97 Tacoma. finally ordered a new one off of ebay. Question is: since it has a leak, the radiator cant pressurize correct? will this cause the water to boil? would it cause an issue with sensors and emissions? just asking cause it also wont pass smog! thanks for any info!
Coolant leak? Inverno4 1st Gen. Tacomas 12 06-01-2013 09:50 AM
Coolant leak EDJY 1st Gen. Tacomas 2 06-08-2011 11:48 PM
coolant leak PeterNM 1st Gen. Tacomas 14 02-13-2011 03:11 PM
Found coolant leak shop caused? ywen 1st Gen. Tacomas 13 12-03-2010 08:38 AM
Possible Coolant Leak??? dbbd1 2nd Gen. Tacomas 7 07-04-2008 07:46 PM
